Author Topic: Panda 30 Head  (Read 1422 times)
jon.hunt
Panda 30 Head
« on: February 03, 2008, 05:08:22 PM »
Nearly There but I'm wondering is it Necessary to alter things so that the Carb. stands Upright rather than at an angle.  To do this I guess there are 3 ways  Machine the Bottom of the Carb,  Machine the Angle on the Manifold were it meets the Carb, or Machine the Manifold were it goes on the Head.   If any should be done I guess Machining the Manifold were it meets the Carb. is the safest Bet, but I don't think the Studs would go Back, I guess I'd have to have some alloy weld put on, then Drill and Tap?   I've got the Head to the 500 shape, and I've had 1mm skimmed off it for High Compression!!!!!!   Did you bother to fit all the Heater stuff Back on?  or Leave that side Bare?
                                                Jon.
