Author Topic: Traffic boils blood and oil!  (Read 1278 times)
« on: January 30, 2008, 01:01:55 PM »
I use my moderately tuned aircooled on a daily basis on my commute to work. The journey is usually about 40-45 minutes each way, but in the last few months, for whatever reason, the traffic has taken a dramatic turn for the worse, bringing my journey time to over an hour each way. In fact traffic is so bad on some of the route, that I am often stationary for long periods of time.
I was wondering a coulple of things, firstly on these old engines, is it a good idea or not to swith off when stationary? Or is the starting up process more damaging than the idling? Also, can anyone offer any advice on keeping the car healthy for these long commutes, as it has been faultless for a good few months, so it is inevitable that something will crop up sooner or later.
« Reply #1 on: January 30, 2008, 10:28:30 PM »
Hi Dom,
Long time noe see!
I've ben using my 500 to drive from SLough to Hammersmith since last sept. It takes me approx 1 hour each way.
I've not had any real issues so far. Few things to watch out for:
Keep an eye on your fan belt, long periods of idle can cause charging issues if its not tight.
start stops are going to wear your clutch out a bit quicker, but thats about it.
Switching off saves you a bit of fuel and is better for the environment, but it will wear your starter out more and if you're not charging enough between switch offs, could drain your battery a little.
Michael
