Author Topic: 126 Brakes  (Read 2130 times)
jon.hunt
126 Brakes
« on: January 18, 2008, 05:42:11 PM »
      I have a air cooler  E Reg 126 and the Brakes work Well, They Stop it OK, But the Pedal Pressure Is High, and my Wife complains that you have to push the Pedal far to Hard, She thinks the Brakes are Crap!!!!!.  Is there anything that I can Do?  Could a Servo be Fitted? or is there not enough Vacumn!!!  or does changing to Discs Reduce the Pedal Pressure?
                   Jon.
banjomandolin
Brake Pedal Pressure.
« Reply #1 on: January 18, 2008, 06:37:00 PM »
If she has been used to a modern car she will find she has to push hard. It's all relative. Practical Classics run a technical Questions and Answers section. Send them an e-mail asking if it is possible to fit a vacuum system.
banjo..
John Clark
126 Brakes
« Reply #2 on: January 18, 2008, 06:49:23 PM »
No vacuum assistance brakes are fitted on the 126 model. So it could be that your wife is just not used to unassisted brakes, have they always been like this? It may be worth checking that you do not have seized brake wheel cylinders? This will cause the car to pull to one side when braking, should also be spotted on the mot test.
