Author Topic: bis stotters and looses power  (Read 2375 times)
sascha
« on: January 16, 2008, 06:20:00 PM »
Can anyone help please? I am completely at a loss as to what to do. My BIS (Pierro) starts reasonably, then after about a mile he startsp to hesitate, I can compress the gas pedal halfway down with any response, then gets slower and slower. When I then stop and wait about 2 minutes, he starts again and runs fine. The baffling thing is that the same can happen when he is warm - out of the blue (warm/cold, any speed, any gear, uphill/straight/downhill he suddenly starts hesitating, I stop, he is ok again.
I have checked almost everything and can't find what is wrong. Tank is clean, fuel pipes are fine, fuel pump is fine. Carb works fine, Jets are clean, Carb is clean, Throttles open ok. Points are good and open fine, I have put a new coil in (no difference), Condenser is ok. Electric wires are ok (no cuts, loose wires or chaffed wires).
Otherwise the engine runs fine, very even, no valve noises, no overheating, nothing.
The only thing I noticed (though this may have nothing to do with the cutting out) I fitted a new exhaust and there is a strong exhaust smell in the car. I need to recheck the bolts but can't see how this can cause a sudden, irregular power loss.
Anybody with any similar experience, please?
Many thanks, Sascha
« Reply #1 on: January 16, 2008, 11:40:59 PM »
is your float in the carb okay ? sounds like a fuelling problem to me , too much by the description.
hudsonhenry
    • http://www.retro500.com
« Reply #2 on: January 17, 2008, 09:44:31 AM »
Have you changed the fuel filter, they are only a couple of quid and if gummed up could cause the kind of problem that you describe.
sascha
« Reply #3 on: February 04, 2008, 11:58:48 AM »
Unfortunately, fuel filter is fine and the float is ok, too. I am close to scrapping it, I am so fed up. Any other ideas? I have put a new condenser in and it starts better but still the same old problem. Suddenly it takes no fuel, you can compress the pedal about 1/3 with no effect, then he starts stottering, and then it's time to stop, wait a few minutes and carry on. I don't mind the waiting bit - but not 3 times on a 25 mile journey. Is there any garage specialising in 126BIS repairs?
thanks very much, Sascha
big_al
« Reply #4 on: February 05, 2008, 09:59:46 AM »
is the new Exhast you put on original? or after market?
(\__/)
(='.'=) This is bunny. Copy and paste in to
(")_(") your signature to help him gain
/\/\/\/\ world domination.
« Reply #5 on: February 05, 2008, 11:53:04 PM »
I would go along with a fuel problem. Is the pump working ok? I would check all the jets again particularly the main jet and fit an inline fuel filter if you don't have one installed.
sascha
« Reply #6 on: February 20, 2008, 07:42:53 PM »
I am loosing my will to live ! I have put a new fuel filter in, I have put a new float in. Same problems - starting is extremely poor (average 5 mins turning before it fires) and sudden power loss when driving. If this happens and I press the clutch (say, at 60) and full throttle, the revs go up and down.
I have checked - the carb gets plenty of petrol on turning and the spark is good. I don't know any more. Maybe she likes pizza in the morning ??
