Author Topic: valve stem oil seal req pls  (Read 1716 times)
chipuk
« on: January 12, 2008, 04:02:14 PM »
Hi.
Has anyone bought a head gasket set thats got the 2 valve stem oil seals with it that go on the inlet valve guides.On earlier 126's they were not used, but on the later ones they were.
Im in need of one, its the small metal/rubber cup item with a spring around the top.It pushes onto the Valve Guide.
If the set you bought has the seals, and you didnt use them, can i possibly buy them please.
rgds
steve
