Author Topic: starting problems - please help!  (Read 2175 times)
claire
« on: January 01, 2008, 07:55:30 PM »
Im having problems starting my 126fsm. We tried starting her today and we could turn her over with a spanner, so attached the battery. She tried turning over 2-3 times, then there was a 'cluck' and a bolt fell out of the engine  :shock: Now she wont turn full rotation whe turning over by hand. All valves move ok etc. When it stops it makes a clunk which seems to come from a bottom endy area. Has any one seen this before?
Im going to drag out the starter motor tomorrow (as there is a bolt missing from that) as soon as its light tomorrow and then try turning over the engine by hand. If this doesn't work im going to have to ddrag out both engine and gearbox.  :cry:  not a job I wanted to do....
Claire
claire
« Reply #1 on: January 02, 2008, 01:50:25 PM »
Oh well, I've ripped of rear fan housing. Nothing, but fan housing is knackered - half the holes were bust and laxking bolts before I eve touched it. Bit of dusty crap in there but nothing to stop fan turning. Starter motor jammed on by one final bolt. Worked on it for near on 1hr then gave up. Need more wd40..... Oh well, I s'pose I'd better rip the engine out  and rebuild the damn thing at the wekend... unless anyone else has any ideas?? Im stumped!!!!
« Reply #2 on: January 02, 2008, 04:38:01 PM »
I assume you sorted the timing before trying to run her as I told you?
claire
« Reply #3 on: January 02, 2008, 05:31:04 PM »
Yep. Timing checked stationary, but hasn't run so not checked with stroboscope yet!
 Also removed the fuel returrn pipe from the rocker cover (?!) It turned over manually and also on the key, but when started on the key a bolt fell out of the engine. There was no nut with the bolt and after tis happened the engine wouldn't even rotate by hand!
When I took bits off today to see if anything had fallen into the fan and jammed up I noticed a number of bolts missing including one from the back of the main block.
Then when I tried to remover the starter motor I noticed that bits like the special bolt with the 'D' shaped head were missing!! Thus meaning that if the oother bolt was from the starter motor then it may have moved, but at present it is stuck as I can't remove the final bolt. If it has dislodged and twisted due to missing bolts it may have damaged the flywheel which would stop the engine rotating.
claire
« Reply #4 on: January 05, 2008, 07:04:04 PM »
Hey, Hey!! Problem identified and hopefully rectified!! Removed gear box and engine this morning, took of rocker cover, head, etc and discovered a VERY squashed nut between the piston and the top of the head.  :shock:   Luckily (mainly due to the shape) valves and piston are ok, just one little scratch. :eek:  Nut, however, is a little squidged oval!!  :lol: Gonna clean up the gearbox etc before putting her back together, but she will NOW turn over by hand!!  :D
jazz
« Reply #5 on: January 05, 2008, 07:32:13 PM »
any idea on where the nut came from?
It will be worth giving the valves a lapping, just to confirm that they are not bent slightly. You should get a nice even grey ring on both the valve and seat if everything is ok.
claire
« Reply #6 on: January 05, 2008, 08:59:10 PM »
The nut in question was a similar size to the ones that hold the carb on. We think that it entered the head through the fuel inlet. The valves should be fine, as they sit at approximately 40% from the flat of the piston. I believe that the engine originally turned over because the nut sat in the respective gap. It would have only flattened the nut once it slipped backinto the flat space between the piston and the bit behind the valves. All in all it was a lucky escape!! Had the nut shattered it would have probably contaminated and shreaded the head.
lilp4130
« Reply #7 on: January 06, 2008, 05:44:41 PM »
well done on getting your hands dirty and finding it!!
it's harder than it looks!
