Author Topic: niki is being temperamental!  (Read 2678 times)
phreak97
  • Niki!
« on: December 28, 2007, 03:54:55 AM »
ok, basically, it is really difficult to start.
it takes a good minute or so of cranking the engine over on and off to get the thing going. usually what happens is itll backfire, then after that itll start first try. once started it runs perfectly fine, except i've noticed a rattly noise when im going up hills.
it started out as a problem that just happened when it was cold, but now it happens eery time. i drove 150kms at 60-100km/h, stopped for fuel, then it wouldnt start, even with the engine as hot as that.
i have cleaned the spark plugs, replaced the spark plug leads, cleaned and adjusted the points, replaced the condenser, and adjusted the timing. a mechanic has fully disassembled and cleaned my carb for me (mainly cos i dont have an air compressor), and he also readjusted it when he put it all back in.
there is a spark when i put the end of a lead next to the engine.
so what the crap?
whats left to test?
phreak97
big_al
« Reply #1 on: December 28, 2007, 09:18:14 AM »
have you checked ur actuall spark plugs and ur fuel filters?
(\__/)
(='.'=) This is bunny. Copy and paste in to
(")_(") your signature to help him gain
/\/\/\/\ world domination.
phreak97
  • Niki!
« Reply #2 on: December 28, 2007, 01:15:40 PM »
oh, yeah, i cleaned out the fuel pump, the brass filter in the carb, and replaced the inline filter. i cleaned the spark plugs, filed the terminals with a nail file. once its started it goes just fine.. but still this starting problem
phreak97
big_al
« Reply #3 on: December 29, 2007, 09:20:44 PM »
it sounds like the choke has been left on make sure it's turning off proply and that ur air filter is in good condition and not blocked :D
(\__/)
jazz
« Reply #4 on: December 29, 2007, 10:14:23 PM »
worth check the valve clearances, when they close up they can cause starting problems!
phreak97
  • Niki!
« Reply #5 on: December 30, 2007, 02:44:25 AM »
thats something i havent done. where do i adjust that and what gap am i adjusting to? i already have a set of feeler gauges if that helps.
phreak97
phreak97
  • Niki!
« Reply #6 on: January 07, 2008, 01:40:28 PM »
ok, i ruled out the choke straight away, i just forgot to mention it. i have now adjusted the valve clearances and the problem is still there. the car has stopped starting entirely, it got harder and harder as time went along, now i cant make it start. all i get is a strong petrol smell.
when it was running, if i let the revs get too low at all (slowing down in 4th too much or something) it'd get all chuggy and run like crap. it didnt used to do that, it used to just take the low revs.
im at a loss for possibilities.
phreak97
phreak97
  • Niki!
« Reply #7 on: January 10, 2008, 12:49:43 AM »
seems like it was the coil after all. when i checked it last i definately had sparks, but when i got the raa to look at it, there was no spark. i've replaced the coil now and it starts no probs.
i still get the funny dead spot when i accelerate though..
phreak97
