Author Topic: towed home  (Read 2912 times)
elbisto
towed home
« on: December 05, 2007, 10:59:08 PM »
where do i start?
my bis has been acting up a bit of late, first the engine was losing power and cutting out and this was put down to the fuel filter being the wrong way round so changed it over and hey presto all seemed fine...
however
last time out she wouldnt start, i thought flat battery so i used the jump leads and she started pretty much straight off, drove 30 miles, no worries, however i did notice a little lost power and chugging, but didnt last.
parked up and went to start again about 20 mins later, started eventually and drove down the road, got to a junction and stalled, was giving plenty revs but just nothing happened, engine became sluggish and stalled, and refused to start. tried jumping it again with the leads and still refused to start, then caught and was revving to keep her going, took the jump leads of and (because the terminals are too thin for the clamps) accidentally pulled off one of the battery leads. big loud bang and then wouldnt start at all. had to call out the repair chap, he looked a bit concerned for a bit and then replaced a relay (one nearest to the windscreen), it solved the ignition problem and she started fine.
Drove about 15 miles home (after a couple of short stops) and the engine starting losing power, there was chugging, and the engine was catching and then losing power, all the time, followed by a brief respite then more, quite dramatic lurching. felt as if there was a fuel flow problem, or the engine was not firing continuously. Eventually ground to a stuttering halt.
She starts and turns over for a minute, let her idle and its ok but as soon as you give it some revs the same thing happens, intermittent power and chugging sound and then stalls.
so towed home and sitting forlornly in the garage.
Any ideas?
Maddog
towed home
« Reply #1 on: December 05, 2007, 11:12:45 PM »
you'll have to run through the normal checks for both fuel and ignition, your symptoms could be either. at this time of year cars often develop starting probs due to the cold and damp but once they are running should be OK
electrical,
 start at the battery with your badly fitting terminals, check the connections at coil, dizzy, your points, condenser and condition of HT leads.
fuel,
  fuel pump, carb or blocked fuel lines/filter or possibly an air leak on the intake manifold.
my first wild guess from your description after cleaning and tightening the battery terminals might be the fuel pump or carb
Richie
Frothy
towed home
« Reply #2 on: December 06, 2007, 12:23:42 AM »
Is the distributor arm or cap loose?
MattW
24hp of Mayhem
towed home
« Reply #3 on: December 06, 2007, 01:38:42 AM »
i would suggest checking your contact gap in the points and the timing. it's usually something as simple as this that is often overlooked.
Take the conact points off and check for wear and replace if necessary, they can be revived with a small file if arcing is obvious as long as they are not too far worn.
Timing is less likely the case, but you mentioned a bang when the batery terminal was disconnected. You can get this if the timing is sufficienlty out. we're at this stage in car age now where the average RAC/AA man may not be proficient with non ecu cars and in the case of 2 pot engines, any problems are doubled because of the lack of pistons
big_al
towed home
« Reply #4 on: December 06, 2007, 08:30:18 AM »
I would check the plugs first and clean or replace if necessary and
I think some models have a carbon filter for the fuel and if this is worn fibers get in ur carbie and block the jets.
Hope it all goes well  :D
(\__/)
(='.'=) This is bunny. Copy and paste in to
(")_(") your signature to help him gain
/\/\/\/\ world domination.
lilp4130
towed home
« Reply #5 on: December 06, 2007, 09:45:22 AM »
check the condenser wire or replace the condenser straight out,
i had similar problems on a journey home broke down 7 times messed wieth the dizzy (i thought it was the timing)she would drive for a bit then die i'd mess about again she'd go for a bit again untill admitting defeat 7th time round and getting towed home!the condenser lead had a little split in it and intermittantly broke/made connection while i was twisting the dizzy then drove for a bit and vibrated loose(as these engines do!)
good luck! :)
it's harder than it looks!
elbisto
towed home
« Reply #6 on: December 06, 2007, 01:31:11 PM »
thanks one and all
one more thing has become evident, which i thikn could be important.
I went to fill up the engine coolant recently and there was a nasty grey slimy sludgy residue inside the cap. I have heard that this could be an indicator that the cylinder head gasket has gone:(
could this be the source of all my woes?
DanRodd
towed home
« Reply #7 on: December 06, 2007, 02:29:29 PM »
mmm,could well be,known as "mayo" in the cap.would also tie in with all your bad running.However,you do get this sludge from overnight condensation,so the only way to be sure is to clean the cap,then take it for a short run to get it hot,then check the cap again,if its still sludgy then i think your head may have gone :cry:
big_al
towed home
« Reply #8 on: December 07, 2007, 07:23:18 AM »
If you have the equipment you can do a compression test this will tell you if you have a blown head gasket and if ur valves sealing completely.
(\__/)
