Fiat 126 Chat
Tuning & Customising 126 Models
bis carb
Pages: [
Topic: bis carb (Read 3028 times)
Tomasz
bis carb
on:
December 03, 2007, 02:12:48 PM »
Hi guys
Am i correct in assuming that the panda 30 and the 126bis have the same carb, a weber 30dgf?
It would make it a lot easier for me if they are cause then i can get one easily.
lilp4130
bis carb
Reply #1 on:
December 06, 2007, 09:37:46 AM »
i have a bis carb if you need one
it's harder than it looks!
Tomasz
bis carb
Reply #2 on:
December 06, 2007, 03:57:53 PM »
Thanks for the offer but the mechanic near me has loads of bis's in his yard. He used to be (and still is i guess) a '126 specialist' but he only has bis's. I will prob get one from him.
Will let you know if i cant though.
Still dont know if there is any difference between the panda one and the bis one. Eventually i will prob get a dellorto dhla 40 but i suppose there isnt much point until i fit a sport cam.
nathan126
bis carb
Reply #3 on:
December 06, 2007, 05:26:37 PM »
Hi Tomasz,
I used to have a panda 4x4, and have both Versions of the haynes manual - so i thought i'd look it up for you.
I seems the panda (1981-85) uses a weber 32 ICEV
and the slightly later panda (up to '93) used the weber 32 TLF
Hope that helps? :
new email address:
[email protected]
jazz
Member
bis carb
Reply #4 on:
December 06, 2007, 05:49:03 PM »
The panda 30 is very different than the 4 cyl panda versions
I have just had a look at the autodata information for the panda 30 and the bis carbs, and they are the same a Weber 30DGF Carb 2V
Tomasz
bis carb
Reply #5 on:
December 07, 2007, 01:09:29 AM »
Cool, thanks guys.
I have heard the weber carbs are better so i a going to fit one of them, maybe this weekend.
bis carb
Reply #6 on:
December 07, 2007, 01:23:44 PM »
the 32 icev is a common upgrade. most bis carbs are in a poor state you can get brand new from kraut-bay for a good price .
Pages: [
Fiat 126 Chat
bis carb
