Author Topic: Different  (Read 5403 times)
Different
« on: November 29, 2007, 03:35:08 PM »
DanRodd
Different
« Reply #1 on: November 29, 2007, 05:05:06 PM »
avoid! ive had 8 Reliants and the engines are a pain in the @ss!
headgaskets always fail on them,parts are expensive,sumps go porus,etc etc
Frothy
Different
« Reply #2 on: November 29, 2007, 06:01:51 PM »
Very smart!
Does anyone fit motorbike engines anymore? I remember seeing a picture many years ago of a Hyabusa engine in a 500, obviously not with the standard gearbox etc.
Frothy
24hp of Mayhem
meuton
Different
« Reply #3 on: November 29, 2007, 06:33:20 PM »
Quote from: "DanRodd"
thats weird I have never had any of those things happen and i have a good few of those cracking little coventry climax engines lying around the garage in various states of tune right up to dry sumped race spec, do you think its maybe using hard english water as cooling? and do you mean the sumps rust through? surely that would be down to poor maintanence?  personally and only personally from my experience those little engines are great and practically unburstable and highly tuneable being the engine of choice for 20 years or so in the 750 race club.
 i have seen a few 500 conversions up close only thing i don't like about it from a personal view point is the modfied rear vallance that sticks out to accomodate the length of the engine,
but hey its all down to personal choice and experimentation at the end of the day and if it rocks your boat good for you lol
cheers Doug
Its slow but it does it in style !!
DanRodd
Different
« Reply #4 on: November 29, 2007, 06:59:07 PM »
they are'nt coventry climax engines,they are Reliants own design engine.
out of the 8 Reliant 3wheelers ive had only 1 didnt have oil in the water or vice versa.yes the sumps rust thru on them.
The climax engines as used in the imp are very good.
Different
« Reply #5 on: November 29, 2007, 07:28:58 PM »
I often wondered about the Skoda 120 engines they were 1 and 1.2 aircooled units, my old 120L flew (Ok it just seemed fast at the time).
jazz
Different
« Reply #6 on: November 29, 2007, 08:11:34 PM »
Was'nt the Reliant engine all aluminium?
If it is it should be very light and should not affect the handling to much.
meuton
Different
« Reply #7 on: November 29, 2007, 11:56:49 PM »
yes Jazz the reliant engine is all alloy design, in fact so light in a reliant robin we used to lift it ontot the stands not bothering with a jack lol... and is indeed contrary to what danrodd beleives developed and designed by coventry climax * way before the hilman imp was ever concieved back in the days when they supplied lotus and other racers with engines and has a very healthy power to weight ratio, a very compact design and well renowned for their reliability.
They have as i said earlier afterall been successfully raced in the 750cc club in their single seaters for over 20 years before being mostly replaced with the fiat fire engine of all things, which also makes a nice unit to drop into the 126 or 500!!  :D The big name in tuning them back then was a well known engine tuner Dick harvey who even wrote a book on the subject "making the Robin fly" which to the racers became the bible. to put it into perspective at the time a 750F (relaint powered) could lap silverstone with its 65bhp at the fly wheel and 7cwt in 1 min 4.8 secs and the porsche 911 class C racer could only manage it in 1 min 8.7 secs now thats impressive stuff he he he....
* (origionally in 700cc form in the reliant regal and rebel then 750cc and eventually 850cc in the robin, kitten, and eventually realto and although over boring can increase them to around the 900cc mark, this is very extreme)
Dajwid I love the idea of the 120 skoda enigne but where would we aquire one to try except maybe chechz Rep or good old Poland maybe?
I have always fancied a 1.7 alfasud twin cam unit myself but never really looked into it in any real way as that much power requires alot of beefing up of just about every component in the little car lol
Cheers Doug
DanRodd
Different
« Reply #8 on: November 30, 2007, 12:23:58 AM »
we shall have to agree to disagree then,because my 1962 edition of the Reliant Review(reliants in house newspaper)says that the engine was designed by Reliants chief engineer Ron Heathcote to replace the austin 7 based unit that Reliant were using in the sidevalve Regals up till late 1961.It was also built originally in 598cc form up untill 1968 when the 700 came in,then the 750 in 1973,and the 850 in 1975.
meuton
Different
« Reply #9 on: November 30, 2007, 12:43:22 AM »
Danrodd
ok we can do that.   :D
the engines lowest capacity was 600cc  but the engine was first put in the Austin seven before reliant bought the "tooling" to produce them under their own name, ( common practice in the industry and much cheeper option than developing an engine from scratch) Where "Ron Heathcote" as head engineer over saw a revised head arrangement and a few other minor alterations, the engine was side valve in its first incarnation from Coventry Climax and was developed for use as a fire engine water pump unit to much success. it was this first design spec that allowed the relaint engine to not require alot of cooling as it was over capacited (the water jackets are massive per volume) due the fact it was intended to located in an enclosed space with no air flow in a fire engine.
cheers Doug
DanRodd
Different
« Reply #10 on: November 30, 2007, 11:18:43 AM »
well to be pedantic the original was a 747.5 engine that reliant bought the tooling to use when Austin stopped making the seven in about 1938.Reliant used the 7 engine after 1937,replacing the twin cylinder Jap engine fitted up till then.It has often been said tho that Reliant simply copied it rather than bought the rights :lol: The first Reliant sidevalve engine was said to have run for the first time on 01 sept 1939,but a certain mr Hitler stopped all that!my 57 Regal has a rare 18hp 747 sidevalve Reliant engine in it,and is vastly different from the first ohvs,it has no oil or air filter for a start!I have to say though in 18 yrs as a Reliant fanatic its the first time that i or anyone in the ROC has heard of this link,the only climax link i could think of was the detuned imp van engine fitted to the Bond 875,and Reliant took over Bond in 1969,but there you are.
Still a nice conversion :D
meuton
Different
« Reply #11 on: November 30, 2007, 12:55:49 PM »
Hi Danrodd
I bow to superior knowledge on these engines it is trully amasing what you can get from books even in this internet world we live in and I will be sure to be asking you for help when i have troubles with my reliant in future.   I guess the fact the engine was chosen because of the requirement to operate in a very confined space must be wrong  :sad: ah well just shows primary sources of information can't be trusted  :eek:
kind regards Doug
DanRodd
Different
« Reply #12 on: November 30, 2007, 01:15:25 PM »
Hi Doug,
I hope i havent upset you or anything, :cry: i can quite understand where your coming from,im sure much of what is written on the net about 500's is wrong and i wouldnt know any different.Its simply that Reliants are a subject that i devoted most of my life to till not long ago so i like to set the record straight as it were.
i can understand why you thought they were similar as there are similarities,its often been said that the ohv Reliant lump was based on a scaled down Herald unit,that i can well believe!The main reason for its development was solely for weight,Reliant having to keep below 8cwt,and the cast iron sidevalve engine was heavy,thus reducing what they could do to make it more civilised inside etc.I doubt it was designed to operate in confined space because Reliants are notorious for overheating,because of the tiny engine bay!
Just wondering as a relative newbie what weakspots there are in the Fiat engines design?
hudsonhenry
    • http://www.retro500.com
Different
« Reply #13 on: November 30, 2007, 02:39:24 PM »
I thought that the Climax engine was fitted to the Hillman Imp not the Reliant.
I originally looked at fitting a Reliant engine into my 500, I went as far as buying an ex 750mc race engine. Its a cracking little engine and can make good power if built properly. The only reason that the 750mc guys stopped using hem is that they became more difficult to source, alough I think they are now being made again.
There are some good pics of Grahams 500 (the one on ebay) on my www.retro500.com site I'm not the biggest fan of all the spoilers and the boot lid but those aside its a very nice car.
meuton
Different
« Reply #14 on: November 30, 2007, 05:33:53 PM »
heres a link to the rebel racing car which uses the reliant engine,
http://www.rebelsracing.com/
and i have to agree with you hudson on the bodykit issue, you never really know whats under all that and all that extra weight too .. remember coventry climax was a development company much the same as cosworth is today
heres a thought how about a skoda 120 gearbox with a lancia twincam linked onto it lol now that would alot of rear end weight and over hang !!!
cheers Doug  :D
