Author Topic: Knock  (Read 2454 times)
jon.hunt
Knock
« on: November 27, 2007, 10:32:19 AM »
    When I'm driving my Air Cooler 126 If I'm in 2nd Gear and take my foot of the accelerator Quickly, I get a Loud Knock from the Back, I think the Engine Moving and banging on something?  Is this Normal, or Ihave my Rear Engine mounting gone, or something Else Please.
        Jon.
Knock
« Reply #1 on: November 27, 2007, 12:08:03 PM »
I have this sometimes. It can often be due to the top of the gear box, or the exhaust hitting the bottom of the car. It has never really been too much of a problem for me. You could try tightening the rear support spring.
jazz
Knock
« Reply #2 on: November 27, 2007, 12:52:21 PM »
It's also worth checking the rear drive couplings in case they are slack or deteriorating.
Knock
« Reply #3 on: November 27, 2007, 02:16:46 PM »
if your mount has gone it will be due to that get a new one on ebay ( german , peter auteil) cheap as chips.
Knock
« Reply #4 on: November 11, 2008, 12:31:04 PM »
Is that big bolt supposed to be as tight as possible or is there some kind of voodoo I should know about it because mine has the same bump and wondering if it should be tight as I can get it.
Knock
« Reply #5 on: November 11, 2008, 09:22:55 PM »
this knock you talk about , is you car lowered? do you have a different exhaust ? i used to get a knock then found that my exhaust was catching on the rear panel when i eased off the accelerator , i had changed both gearbox mounts and rear engine mount so they were fine. i also find that if the car is lowered and has a harder suspension then it makes the engine bounce about a bit at times.
  if it bangs too much just look through your rear view mirror as your engine bounces down the road after you ....
Knock
« Reply #6 on: November 13, 2008, 04:15:41 PM »
I took about 3/4 of a coil out the back springs, dont think it can be anything to do with that as I've seen some on here that look like you could do yourself an injury going over a speed bump.
Bump doesn't go with bumps in the road, it is just accelorating and de-accelorating.
I made my own exhaust by taking the standard pipe off the 650 air cooled, cutting the out pipe off which revealed the out pipe was part of a baffle which goes all the way through the silencer and tacked on the ther side.
This was removed and an elbo of larger diameter welded in place.
The angle of the elbow was checked by shaking the engine as much as I could, the pipe did not touch although had to be cut shorter than the original as it started to touch stuff.
To me it sounds something either to do with transmission or that big mounting...
I recon I'm going to sit on the back and get my sister to drive it in a nice quiet spot.
Only problem with air cooled is you can't drop the seat, open the lid and see the engine working!
Knock
« Reply #7 on: November 13, 2008, 04:52:09 PM »
check the back L/R gearbox mounts if they have cracks in the rubber they need to be replaced the engine twists on them when accelerating/de-accelerating :wink:
Knock
« Reply #8 on: November 14, 2008, 09:35:53 PM »
I replaced both mounts when I repaired the gearbox. :???:
Knock
« Reply #9 on: November 14, 2008, 11:00:47 PM »
just out of curiousity when you repaired the gear box did you take apart any part of the crown and pinion? and if so did you test it for backlash afterwards?
Knock
« Reply #10 on: November 18, 2008, 10:55:16 AM »
Ah!
To be honest I just put it back together and thanked the lord that the noise went away.
I can hear my radio up to 40mph now!!! :cool:
Knock
« Reply #11 on: November 18, 2008, 11:20:12 AM »
well if theres any noises just turn the radio up!
