Author Topic: Problem with electrics- everything just went off!  (Read 2228 times)
kingofkeyrings
    • http://www.classiccapsule.co.uk
« on: November 12, 2007, 04:59:23 PM »
Hello everyone...
Driving our 126 BIS on Sunday. Sudden bad smell of something electrical expiring. Then no electrics, just engine ignition electrics and indicators! :shock:
Checked all fuses they're fine. Is there the mother of all fuses somewhere, is it a relay or something dafter than that?
Any help would be gratefully accepted before I pass it to a man with a multimeter who charges by the hour!
Making more old Fiat stuff than you can shake a stick at!
DanRodd
« Reply #1 on: November 12, 2007, 05:30:10 PM »
have you checked the inline fuses as well?
kingofkeyrings
« Reply #2 on: November 12, 2007, 10:29:57 PM »
Thanks for that, where are they as they don't mention them in the handbook? Do they look like normal in-line fuses or are they weird things well hidden?
DanRodd
« Reply #3 on: November 12, 2007, 11:04:13 PM »
they are (at least on my fsm) torpedo shaped black cases with a little fuse inside,my ignition one was loose so i lost all ignition and lights.
jazz
« Reply #4 on: November 12, 2007, 11:29:24 PM »
just checked a bis wiring diagram I cannot locate any inline fuses on this model?
First check I would do is the ignition switch, check which cables have power, looking at the diagram you should have power in the red and brown at all times. The others should have power with the ignition switch on.
kingofkeyrings
« Reply #5 on: November 12, 2007, 11:29:48 PM »
Magic that's encouraging!
Where are they located? Under the bonnet or inside car?
kingofkeyrings
« Reply #6 on: November 12, 2007, 11:35:16 PM »
Thanks for the tip about the ignition switch. That sounds very plausible. I'll have a look tomorrow....
