Author Topic: Timing  (Read 4397 times)
Setch126
Timing
« on: November 11, 2007, 07:36:02 PM »
Hi to all
Just got a 1987 BIS. Not been started for 7 yrs, 23k miles in good order.
Having 'issues' with starting. The 'little gem' has occupied 2 days of my time (+ 12 yr old son who is learning fast). We have loved every second !
It seems to be firing but only runs (for a very short time) when I depress the accelerator fully, on what sound like 1 cylinder and pops back through the carb. This is with a temporary can of fuel and gravity feed.
I have compression checked and am getting 120 psi on both cylinders.
So far:
1. Deduced that the fuel pump is faulty so intend to fit an electic pump.
I have read that the fuel line nearest the rear of the car is the return, but then got confused as I also read that it was the feed...which is the feed ?
2. Ignition, how do I know when I am timing number 1 cylinder ? (read this is nearest to flywheel) ?
The timing marks on the crankcase have 3 'points', presume biggest is TDC with other being values BTDC ? Which one do I use ?
Any advice most welcome.
Nick & Alex
1987 126 BIS Blue
DanRodd
Timing
« Reply #1 on: November 11, 2007, 07:42:18 PM »
only recently bought my aircooled 126,but assuming the Bis has the same ignition coil it could be that the coil has broken down like mine did,and only worked on one side.also check and replace your points and condensor before delving into things like the timing.
Setch126
Timing
« Reply #2 on: November 11, 2007, 07:54:49 PM »
Quote from: "DanRodd"
I have checked the points and cleaned faces etc, they seem OK, Also changed condenser. I have 12V at the points and have checked (using an earthed spark plug) that the plugs have a good spark, both do.
Is all happenning in the right order though? 2 cylinders is enough to confuse me these days !
Trying to remember my timing knowledge...not used for some 25 yrs now, last used on my Ford Escort Twin Cam rally car !! Happy days.
1987 126 BIS Blue
Timing
« Reply #3 on: November 11, 2007, 10:10:17 PM »
no 1 is at the rear of the car
jazz
Timing
« Reply #4 on: November 11, 2007, 10:30:00 PM »
Here is an online manual for the bis model
http://www.fiat126.hu/book.php?book=15
it may help you? :D
Setch126
Timing
« Reply #5 on: November 12, 2007, 04:05:13 PM »
Discovered so far:
1. Fuel pump U/S.
2. Compression check seems OK , 120psi in both cylinders.
3. 12 volts at dizzy.
4. Spark at each plug.
5. Fuel bowl has fuel in it.
assumptions I have made:
1. the cylinder nearest the back of the car is number 1
2. the timing marks are TDC, 5 BTDC and 10BTDC.
3. As you look at the coil, the left hand lead is number 1 cylinder.
Done so far:
1. Dizzy out, checked points and cleaned faces, gapped to 0.4mm.
2. Condenser changed
3. New plugs inserted, gapped to 0.7mm.
4. Rigged can up with fuel in it as temp fuel supply.
5. Cleaned carb in situ (jets out, air gunned).
6. Rotated engine with a rod down number 1 bore, to confirm at top of stoke with TDC mark on pulley.
7. Rotated to 10 degree TDC mark on pulley.
8. Dizzy clockwise rotated, so points just about to open (used multimeter to get precise).
It fires but only when to accelerator is pushed down; runs on what seems like 1 cylinder for approx 3 seconds, then stops when accelerator released.
Popping back through carburator.
I am thinking:
1. Have I timed it correctly ?
2. Is the carb blocked ?
3. Does it need a positive pressure on the fuel supply side ? (I intend buying an electric fuel pump..3 psi ish).
4. Am I going mad.
5  Is their something terminal ? (Comp check seems OK ?!)
Help !!
1987 126 BIS Blue
Maddog
Timing
« Reply #6 on: November 12, 2007, 07:10:29 PM »
just replace the fuel pump(£5 pff ebay) or parts of it that are knackered, they are perfectly adequate for stock car and it will probably run perfectly as you have checked everything that needs to be checked, there is a diagram of the timing marks in the bis manual above.
I don't think the bis carb has an enrichment pump or diaphram so if you have cleaned it properly it should be fine, the odd running is probably due to too little or too much fuel pressure, its not possible to put the dizzy on 180deg out so as long as the points are opening the timing will be close enough to at least run, get the pump sorted first
lilp4130
Timing
« Reply #7 on: November 13, 2007, 07:27:45 PM »
sound stupid but try swapping plug leads also
if youve had the dizzy out it is possible to put it back in wrong as i have done
there is not alot of rotational movement so if this is slightly wrong you may not be able to set the timing correctly
take out the dizzy and spin the lower gear about a quater turn and replace
then try timing it again by rotating the dizzy both ways i did this with the dizzy nut just tight enough to be able to twist it with a bit of force get the boy to keep turning the ingition on and off while you rotate the dizzy good luck mate!
it's harder than it looks!
Setch126
Timing
« Reply #8 on: November 15, 2007, 07:10:33 PM »
Great advice chaps, thankyou. Will give it a go this weekend.
Will let you know how we get on.
1987 126 BIS Blue
Setch126
Timing
« Reply #9 on: November 17, 2007, 08:23:22 PM »
Quote from: "Setch126"
Got it started, driven around, got all 4 gears, no nasty noises excellent.
Engine came nicely up to temp.
Came to it this morning, blow me, difficult to start again.
Running on choke for 5-20 seconds then stops. Second I touch the accelerator, it stops too.
I think it could be a carbuartion problem, intend to clean carb out thoroughly...had top off and all looked OK (carb top that is not mine!), but I will remove whole carb and do a better job.
Any thoughts ?
PS just how do you get that carb nut off (the top right as you look at the carb) ?! Struggle presumably ?
1987 126 BIS Blue
Setch126
Timing
« Reply #10 on: November 18, 2007, 04:09:23 PM »
Any thoughts ?
It lives.
Running sweetly now, cleaned car out, replaced a few ruber seals.
Wonderous
1987 126 BIS Blue
Timing
« Reply #11 on: November 18, 2007, 08:16:56 PM »
Any thoughts ?
Mine does this on a cold morning, I think it is caused by condensation in the exhaust, after it is running on no choke at all just let it warm up and when the water has cleared it should run fine.
Setch126
Timing
« Reply #12 on: November 29, 2007, 01:38:36 PM »
thanks to all.
The sewing machine lives and sounds great.
Bit more prep then its off for an MOT.
Will keep you posted.
1987 126 BIS Blue
Setch126
Timing
« Reply #13 on: February 17, 2008, 07:08:56 PM »
thanks to all.
Passed MOT last Friday !!
Initially failed on headlamp aim and telltale light for indicators (sure it stopped working on the way to the MOT).
CO was high but a little tinkering got it within the 3.5% allowed.
I think it needs the timing sorting a bit then the carb..next job.
Car drives superbly
Nick
1987 126 BIS Blue
