Author Topic: Would you recommend this 126?  (Read 2099 times)
sk39
« on: November 05, 2007, 11:36:16 PM »
http://cgi.ebay.co.uk/Fiat-126-BIS-1989_W0QQitemZ290178459169QQihZ019QQcategoryZ9843QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Could the noisy driveshaft be serious or is it common with these cars?
Gateshead....bit far from london so transportation will have to be arranged. Anyone reccomend me a transportation company or someone who would be willing to transport the car for a certain amount?
thanks
« Reply #1 on: November 06, 2007, 08:11:40 AM »
it aint much of a problem driveshaft bearings do go and even if its a bit noisy it will be ok to drive back to yours. the sill (hole 1 inch) could be just the tip of the iceberg but if you are prepared to do some sill work its ok. if you get this car make sure you have home recovery on the car and if you break down on the way back its loaded up and shipped home otherwise it will cost a mint to get back . if you are prepared to pay good money to get a car back to london why not buy nearer but dearer?
also what are you really after a bis or aircooled ? as i might just have something ....
sk39
« Reply #2 on: November 06, 2007, 05:41:04 PM »
I dont really want to be doing much work and am generally looking around as i am interested in a 126, bis or aircooled doesnt really matter.
sk39
banjomandolin
Noisy driveshaft.
« Reply #4 on: November 16, 2007, 08:28:06 PM »
Noisy driveshaft. My favourite soap box topic. Lack of lubricant at the driveshaft outer end where it's male splines mate with the steel flange which in turn bolts on to the flexible coupling. It's bad news if you have to change a driveshaft because you have to remove the gearbox and delve inside the crown wheel and pinion assembly.
banjo. :sad:
John Clark
