Author Topic: Petrol Pump not pumping fuel !!!!  (Read 2380 times)
gserghiou
« on: October 25, 2007, 04:52:24 PM »
I have tried to start the engine on the 126 i got a couple fo days ago...
to cut a long story short, the petrol pump does not seem to 'suck' and 'spit' petrol to the carburettor....
Could this mean that the problem is solely the petrol pump, or could it be something in the carburettor stuck that 'tells' the petrol pump not to pump any petrol ???
any ideas would be appreciated !!!!
Also, i put the jump leads BY MISTAKE (i was ina hurry) the wrong way...connecting the + to the - and vice versa....i smelled burned rubber and saw some smoke coming out of the alternator and the brown wire got really hot and the sheathing got a bit burned...not much...just got really hot !!!!
DID I FRY the alternator to its death, is it serviceable or could it be still ok ??? how do i check ???
Thanks,
George
(Cyprus)
maxlee
    • http://www.trampdrift.com
« Reply #1 on: October 26, 2007, 12:37:35 PM »
donnt know about the elc side of things but fuel pump
take the fuel pump off think its 2 10mm bolts and it is driven by a metal rod some times these were out. why its off you can also press the fuel pump drive with your finger and here if its ok
TrampDrift its for winners
gserghiou
« Reply #2 on: October 26, 2007, 01:08:05 PM »
thanks,
i also talk to a feind of mine who undestands about 126s and said the same thing. he says its purely pump problem...so i will take it off and check it out !!!
Thanks,
George
(Cyprus)
« Reply #3 on: October 26, 2007, 05:21:00 PM »
New pump is very cheap, pop a new one on, then check and change all the hoses while you are at it. about £8-£10 well spent
gserghiou
« Reply #4 on: October 26, 2007, 08:36:28 PM »
ok...the scenario...
removed the petrol pump from the 126P and it seemed dead...let it soak in petrol to see what happens...
meanwhile, i have a 600 cc block...which luckily had a pertrol pump still on....
removed that one and presto...it works.... cleaned it up a bit and put it on the  engine....
could not get petrol in the tank as the rubber hose leading from the petrol cap to the petrol tank is perished.... so i coned up a water bottle and fed it a bit of petrol....
put the jump leads on and pushed the started with my stick (the starter cable broke and im getting a new one) clak clak clak clak clak. and she run nicely enough for the first time ni ages....
i let her run for a bit more and then i t coughed a bit and went off....luckily it was short of pertrol !!!!!!
Started taking off the brake pumps from the wheels waitin for the new ones to arrive and install them.... also will change main break pump...shock absorbers look to be in good nick (shiny tops sugget recently changed (2-3 years ago maybe)
also tried to fix teh passenger side window the window mechanism cable is snaped... i used the FSM passenger side mechanism as a donor....
i dont habve any expericnes with this mechanism so i made a small mess of it (i got the cable caught in the gears of the mechanism and damaged them...
So, im on the right track of getting her running ready for MOT and then registering it....
Oh..al the seats are out of the car as we speak to  get cleaned...they need it !!!
One more question please.... regardin ghte window mechanism....
as i said, the passenger side mechanism is not good...so i replaced with passenger side from FSM...but due to bad luck and inexperience, i 'recked' the FSM mechanism.... so im left with one more option...use the FSM driver's mechanism to the passenger side on the 126P !!!! Will that fit or is is it an opposite mechanism !!! ???
Also, if it can be 'transplanted' what should i take care to do so that i do not mess it up, and when installed will work proplerly adjusted. i.e should i make sure to note the position of the window  , fully up or fully down) remove the mechanism and then install to 126P having the window in the same position ?????
Help with window please !!!!!
i will try to attach a couple of photos, but photobucket is messing up at teh moment....when its back online i will post them !!!!
Thanks,
George
(Cyprus)
ko...photobucket is up....
here are some photos i took at the night after washing the car (it was realy really DIRTY !!!!) also cleaned the interior out (it still neds a lot of cleaning...maybe new uphostlery...cause the cat had a nice sleeping place !!!)
banjomandolin
Fried alternator.
« Reply #5 on: October 26, 2007, 11:53:10 PM »
Regarding the fried alternator is the dashboard ignition light on when the engine is running ?. If it is you have a problem. If not you need a test meter to test the alternator output. Reading should be around 14.4 volts. Go to Halfords for a test meter  Ã‚£20 - £30..
banjo.
John Clark
gserghiou
Re: Fried alternator.
« Reply #6 on: October 27, 2007, 07:48:54 AM »
Quote from: "banjomandolin"
banjo.
Thanks for the reply...
wil check today and proceed accordingly !
George
(Cyprus)
