Author Topic: Petrol Leaking on my bis  (Read 2139 times)
elbisto
« on: October 19, 2007, 02:09:37 PM »
I am having a confusion over a series of events, i shall set them forth thus:
MOT failed so had to install a new petrol tank
Put the new tank on (taken from a spare car) and attached the fuel pipes from the spare car too.
Car started cutting out a lot. On taking it in to the garage i had broken down next to, turned out the in line fuel filter was the wrong way round.
just before the filter was reversed to be the correct way around the petrol tank appeared to be leaking fuel. the tank was nearly empty and i have since checked that there are no holes in the bottom of the tank, i also know this because it had 10 litres of petrol in it before i removed it from the spare car.
When i parked up it had a puddle of petrol around it, with a nearly empty tank. I then took it to the petrol station and filled it up. It continued to leave a puddle of petrol when parked.
Filter was then turned round the right way.and she no longer cuts out
I drove the car home, parked her up and left her for a week, due to the (presumably) leaky tank. There was still some petrol on the garage floor, but not a continuous stream. I have since dried off the bottom of the tank (which is now only half full) and for two days there has been no sign of the leak.
I have tried driving her a couple of times and still no leakage evident.
My Problem is - why would there be this leak in the first place??
could it be - the fuel filter the wrong way round has not allowed the right amount of fuel through the pipe, therefore backing it up in the pipe coming from the fuel tank, and causing it to leak over the top of the fuel tank?
is there a hole at the top of the fuel tank, if so, why did it leak before i filled the tank up??
I am planning a lenghty trip next week and would like to get to the bottom of this before i go, has anyone got any ideas or advice?
« Reply #1 on: October 19, 2007, 04:02:38 PM »
when you replaced the tank did you use new fuel lines ? if not the fuel lines might be leaking because they crack with age. do you get a fuel smell in the car? have you checked the filler neck is fitted correctly?
elbisto
« Reply #2 on: October 19, 2007, 05:17:57 PM »
no i used the original fuel lines that came off the spare car, however there is no petrol smell in the car, and at the moment seems to be no evidence of fuel leaking from the pipes (will be checking frequently tho)
The filler neck is also attached as it should be to the tank and no signs of a split in it either -  took off the inner rear panel to check it was ok.
The real mystery seems to be - at the moment - why there had been a leak and now there is no longer one. If that changes of course, i can check the pipes etc, but with a full tank and no apparent leak any more - a real puzzler
maxlee
    • http://www.trampdrift.com
« Reply #3 on: October 22, 2007, 01:46:44 AM »
sure its not leaking from some were eles then running back down a pipe to the top of the tank then on the floor??
petrol spreds out very easy you drop 1p's woth on the floor look back and it looks like loads  :shock:
has it got a overflow pipe on the top of the tank like othere cars also if a breather pipe is blocked some times couse little problems
TrampDrift its for winners
