Author Topic: no spark  (Read 2478 times)
maxlee
    • http://www.trampdrift.com
no spark
« on: October 15, 2007, 03:30:14 PM »
:sad:  right got the old beast ready to start to day and no spark is there any little things that you can over look that can give this problem
also is the restior (box with 3 wires of it and a coil of wire in it) any thing to do with the spark system its located under the bonit behind the spair wheel at the front. or is it just for the heater fan i will post a post in a sec about my new project  :wink:
TrampDrift its for winners
Wozza
no spark
« Reply #1 on: October 15, 2007, 06:41:49 PM »
Hi Maxlee, The first thing I check is the Condensor and points gap mate. after you've checked the gap with a feeler guage, and the ignition off, switch her on again. Then flick the points open with a plastic handled screwdriver. If you get a good sized slightly blue spark between the points when you do this, then its probably the condensor thats faulty because they are supposed to prevent that sparking. My condensor lasts about 6 months normally because of the state of tune of my engine, so i always carry a spare. If thats not your problem then i would try checking your spark plugs and leads, then your static engine timing, and then possibly substitute your coil for a known working one, in that order.Another test that i would always carry out, is that there is fuel being delivered by the carb: remove the air intake housing and then look for petrol being squirted in when you pull on the accelerator linkage. hope that helps mate.
maxlee
no spark
« Reply #2 on: October 15, 2007, 07:56:15 PM »
cracking thanks wozza
i see onthere post on this and checked the white ire that was brought up in convo but all seamed ok then run out of day light  :cry:
i'll try every thing above tomorrow if the rain holds off  :lol:
i found it has no spark by taking one of the plugs out and trying to difrent plugs and 2 difrent ht leads wile holding the spark plug on the engine  :D
deffo getting fuel
will post out come 2moz  :D
no spark
« Reply #3 on: October 15, 2007, 08:27:07 PM »
Another common mistake is incorrectly instaled points. If you do not get a spark at the points. Check that they are fitted ok? I think it's usualy the points spring in the wrong location (therefore not insulated)
maxlee
no spark
« Reply #4 on: October 15, 2007, 11:47:30 PM »
:D  thankss added to the list of to check tomorow
maxlee
no spark
« Reply #5 on: October 22, 2007, 01:51:14 AM »
you guys rock it was the points  :D it run and sounded ok to me :)
needs new leads tho and service still but when some thing runs it gives me more get up off my ass and do it  :D
