For Sale & Wanted
Wanted:
650 head
Pages: [
Topic: 650 head (Read 2766 times)
ger
Member
650 head
on:
October 12, 2007, 09:33:22 AM »
Hi Folks,
Does anyone have a spare 650 head lying aound that they want to sell......
I was removing the exhaust elbows last night and managed to shear off the studs....
Gerry
Gerry
(Near Glasgow, Scotland)
http://www.dropshots.com/ger
(500 all done MOT'd !)
650 head
Reply #1 on:
October 12, 2007, 09:41:06 AM »
oops... i did this and had to drill them out. you can do this if you have the right tools. but do not use a reverse thread stud remover as it will break for sure!! then you must drill that bugger as well!! go slowly and they will come out.
ger
Member
650 head
Reply #2 on:
October 12, 2007, 10:15:22 AM »
I did drill them out and retapped to M8........But I'd still like to have a spare head ....just in case !
I had bolts in mine, studs would make so much more sense, thats what I'llbe replacing them with....
Gerry
Gerry
650 head
Reply #3 on:
October 12, 2007, 10:19:03 AM »
i had studs and they still shear off when you try them . it must be the originals just get brittle with all the heat and age. so new ones should be fine.
have a look on german ebay "peter auteill" has got new heads normally and he is cheap.
meuton
650 head
Reply #4 on:
October 12, 2007, 10:25:34 AM »
Hi Gerry
fitting helicoils in the tapped holes is always a good alternative to just retapping the holes to a bigger size as it removes the oxidisation issue due to the threaded coils being usually stainless steel and once located into the alloy a much stronger fixing than the origonal alloy thread, also as i know you will have done a little copper ease on the bolt threads goes a long way to easing ht eproblem of ceased bolts shearing
cheers Doug
Its slow but it does it in style !!
ger
Member
650 head
Reply #5 on:
October 12, 2007, 11:00:42 AM »
Cheers Doug !
I have a big tub of copper ease, comes from a long time of working with old junk !
Gerry
Gerry
Tomasz
650 head
Reply #6 on:
October 17, 2007, 02:58:22 PM »
i also have a spare head but it has regular holes on one side and large studs on the other from having to retap it twice!
650 head
Reply #7 on:
October 17, 2007, 06:28:47 PM »
i have a complete head here,dunno if studs or bolts,but is in good nick,took it off to put panda head on...........pain to pack and send tho,but if you get really stuck give me a shout
Pages: [
For Sale & Wanted
Wanted:
650 head
