Author Topic: Checking the Coolant Level  (Read 1970 times)
stormboy68
« on: September 28, 2007, 04:45:46 PM »
I am afraid that i have another dumb question but i guess , if you don't know - you don't know !
The red coolant indicator light has come on to suggest i need to top up.
Do i just poor coolant into the entry hole (!) at rear of car and guess how much to put in or is there a level indicator somewhere ?
jpimpao
« Reply #1 on: September 28, 2007, 05:24:43 PM »
I would just top up until the light goes off as the engine gets hot the coolant will expand , well that`s what I have done to my Bis and works very well.
Hop it helps.
Jorge
Wozza
« Reply #2 on: September 28, 2007, 05:34:50 PM »
The best thing to do is to top it up slowly with the ignition turned on so that you, or an assistant can tell when the light goes out. Next, open your heater matrix bleed screw under the bonnet, then, with the heating control up to maximum, and the expansion bottle cap removed, run your engine until water is pumped from the bleed screw. Tighten it straight away, and then re-check the coolant level in the expansion bottle, and stop the engine.
stormboy68
« Reply #3 on: September 28, 2007, 07:15:31 PM »
Cheers . Just thought i would check !
Still having problems with no dipped headlights but all other lights working. Not sure what is causing this ?
