Author Topic: Pump spacer  (Read 3745 times)
Pump spacer
« on: September 23, 2007, 06:28:52 PM »
Managed to get a spacer off a 500, was tightening and I heard a crack.
Ooops new pump knackered.
Could someone measure the thickness of their spacer seen below?
Dave
MaLi
Pump spacer
« Reply #1 on: September 23, 2007, 07:58:55 PM »
Hi Dajwid,
My service book says:
- thin gasket thickness: 0.3mm (the one between plastic isolator and engine block)
- isolator thickness: 20mm
- gasket between pump and isolator: 2mm (also made as 0.3mm, 0.7mm, 1.2mm)
Hope that'll help.
Mali
Edit:
Push rod should be sticking out of the last gasket by 1.0..1.5mm
Pump spacer
« Reply #2 on: September 23, 2007, 08:35:09 PM »
Thanks, I will have a look tommorow.
I have a feeling the pushrod is sticking out further but will check.
Pump spacer
« Reply #3 on: September 24, 2007, 02:25:08 PM »
that is the wrong size it should be about 20mm thick on the 652 engine.
Pump spacer
« Reply #4 on: September 24, 2007, 05:56:46 PM »
Hence the knackered pump, Ooops.
OK I will have to get one :-(
MaLi
Pump spacer
« Reply #5 on: September 24, 2007, 10:13:35 PM »
or just shorten the pushrod      :smt047
Pump spacer
« Reply #6 on: September 25, 2007, 02:31:16 PM »
if you shorten the pushrod that will involve a lot of guess work as a standard rod is pain enough to set properly what with the shims if done correctly.
MaLi
Pump spacer
« Reply #7 on: September 26, 2007, 09:16:57 PM »
Dajwid,
I am going for a weekend to Poland this week.
I can have a look in a local shop for the spacer if you want.
Mali
Pump spacer
« Reply #8 on: September 26, 2007, 10:26:39 PM »
Thanks sent a PM
MaLi
Pump spacer
« Reply #9 on: October 02, 2007, 10:36:39 AM »
Job done. Please send me your address on PM.
Pump spacer
« Reply #10 on: October 04, 2007, 05:57:48 PM »
Thanks a million, Part came today, needed slight modding to fit, but is on.
I owe you a pint (or two).
Dave
MaLi
Pump spacer
« Reply #11 on: October 04, 2007, 08:37:51 PM »
Cheers  :smt040
