Author Topic: Starter motor  (Read 2183 times)
jpimpao
Starter motor
« on: September 12, 2007, 12:21:04 AM »
Today I have changed the engine oil, tuned the carburator and the engine worked fine , even I did went for a trip on Sunday about 80 miles and no problems.
Now the engine does not start, the dash shows all the lights, battery is OK but when I turned the key to start the engine nothing happens, looks like the starter motor is dead. Pull the car for a bit , engaged 2nd  gear and the engine started to work fine, is there a problem with the starter, I have checked all fuses and seems to be ok, any help would be much aprecciated.
thanks
Jorge
Maddog
Starter motor
« Reply #1 on: September 12, 2007, 02:45:07 PM »
check that the main feed is connected properly to the top of the starter, its a spade and can sometimes come loose, and that it is getting power,
 if it is ok then check that the  ignition feed to the starter is getting power when you turn the key to start position, obviously need someone to turn the key while you test with a multimeter.
be careful whilst doing this as earthing either of this wires will cause a big spark and possible damage :shock:
Richie
jpimpao
Starter motor
« Reply #2 on: September 12, 2007, 07:45:27 PM »
Hi, Thanks for ypur help I did check the wires at the starter coil and one was loose , now works fine.
Jorge
stormboy68
Starter motor
« Reply #3 on: October 19, 2007, 05:22:45 PM »
I am glad i have read this today as my Bis has done exactly the same last night. Not had time to check it yet but from memory , there are 2 connectors ' this end ' of the starter motor - are they the connectors that need checking or is the main feed elsewhere?
Am i the only one who finds access to the starter really hard or maybe i have excessively large hands !
Starter motor
« Reply #4 on: October 19, 2007, 06:40:35 PM »
if you remove the air filter box first you can see the connectors from the top
Frothy
Starter motor
« Reply #5 on: November 16, 2007, 05:48:23 PM »
Glad you got it sorted, always nice when there's an easy fix. On mine the soleoid sometimes sticks and it needs a bit of encouragement i.e. clouting it with a spanner.
Frothy
24hp of Mayhem
