Author Topic: Bis Handbrake cable adjustment  (Read 1737 times)
elbisto
« on: September 02, 2007, 08:47:06 PM »
Can anyone advise me on a bit of an urgent query, only one day till MOT day!
The handbrake ive been told is not effective enough. Ive tried to adjust by tightening the cable, and have been semi-succesful, one side is tight however i cant get the drivers side cable end to tighten very far - the nut is very stiff and i cant get my akward 19mm spanner in properly, with the exhaust and such like in the way.  What id like to know is , given that the cable is operated by a single lever, will the two sides even themselves out? or will i have to pay the garage to tighten the other side (which i really dont wanna do!), or can anyone suggest an easy solution?
banjomandolin
Handbrake Adjustment.
« Reply #1 on: September 03, 2007, 11:55:55 PM »
It's very awkward. The normal 19mm spanner is too long. When I did it I considered cutting a spanner in half but managed without so doing. You have to disconnect the cable from the anchor point (i.e. the lug welded to the control arm with a slot in it with a nut on either side of it) at each wheel and then as you loosen one nut you tighten the other. The cable is compensating but I found that you need to take up the slack at each wheel to achieve sufficient overall adjustment. I found a short adjustable spanner came in handy. You need plenty of WD40 at the anchor points.
Banjo.
John Clark
elbisto
« Reply #2 on: September 09, 2007, 11:00:26 AM »
thanks banjo, passed its MOT, the garage still had to adjust the shoes, but what id done to the cable had been sufficient.
then it broke down
 :cry:
just started losing power in 3rd gear, then stalled. I had broken down next to a very unhelpful garage, who reluctantly took a look at it, and told me i have a loose earth strap, now tightened, hit the starter motor with a hammer and again, she rides! we await a further test drive, to see if theres anything more serious, the huge oil leak is not helping either
