Author Topic: Is it time to clean the oil filter  (Read 2077 times)
« on: August 31, 2007, 07:27:49 PM »
My 126 was leaking oil out of the flywheel end of the engine, so i put that down to rear crankshaft oil seal.
The car has only done 18k but when i checked the end caps the bearings were completely shot. also the big ends were in the same condition so they all need replacing, the engine was'nt that noisy but this is what i found when i took the centrifugal filter pulley off,
This is what it should look like, maybe that is where all my problems have stemmed from, so if you've never cleaned the filter out be warned.
« Reply #1 on: September 03, 2007, 09:45:26 PM »
blimey, good job done pete ive never seen one that bad!!
but ive never seen one so clean after its been de gunked!! looks new.
i really enjoy cleaning them, does the alloy disc have to go back on in a certain way? i.e. are there markers?
regards
banjomandolin
Oil Filter,
« Reply #2 on: September 04, 2007, 12:10:09 AM »
There are no markers. You just keep trying untill you find the one where all the holes align but beware. There is one position where the holes almost align but don't be tempted. Keep going till the holes align perfectly. Then make your own marker for the next time you do the job.
Banjo.
John Clark
« Reply #3 on: September 04, 2007, 07:51:50 AM »
As Banjo has mention the holes only line up in one position, before i took it off i used a punch to put alignment marks on. Makes it easier.
just onething more to mention don't attempt to clean it without  removing the pulley or you will get some of the crap down the oil ways,  you will need a 32mm socket to remove the hollow nut.
« Reply #4 on: September 08, 2007, 08:18:03 AM »
the alloy cap has the timing marks on it hence the staggered fixing holes.....
