Author Topic: Gearbox oil change  (Read 2878 times)
jpimpao
Gearbox oil change
« on: August 31, 2007, 01:03:02 AM »
Hi all,
i would like to change the gearbox oil on my BIS but i don`t know where the screws or bolts are positioned, to drain and fill up the gearbox.
The Bis manual doesn`t show how to do it. Wondering if anyone has a picture of it.
Jorge
jpimpao
Gearbox oil change
« Reply #1 on: August 31, 2007, 09:04:19 PM »
Hi all,
I did managed to find the plugs to fill up and drain the oil, the fill up plug is square and the drain plug is hexagonal, does anyone knows the size of the tool I have to buy to take out the drain plug.
Jorge
Gearbox oil change
« Reply #2 on: August 31, 2007, 10:40:21 PM »
thinks it's an ordinary 17mm socket?
update
I might be wrong check out this thread
http://fiat126club.co.uk/forum/viewtopic.php?t=1060&highlight=plug
jpimpao
Gearbox oil change
« Reply #3 on: August 31, 2007, 10:48:38 PM »
Hi Chris,
It is a hexagonal plug ( Drain plug )
Jorge
jpimpao
Gearbox oil change
« Reply #4 on: September 01, 2007, 02:50:23 PM »
I have changed the gearbox oil and Halfords sells the socket to take out the drain plug for £ 3.49, it is a HEX 12mm.
Jorge
Tommo32
Gearbox oil change
« Reply #5 on: September 01, 2007, 05:51:10 PM »
use a 12 mm allen key then! and usually a ratchet will fit into the square ones, either 3/8's or 1/2" drive
