Author Topic: Crankshaft Bearings  (Read 3968 times)
Crankshaft Bearings
« on: August 26, 2007, 07:09:11 PM »
this weekend i was going to replace the crankshaft bearing oil seal, when i unbolted the c/s carrier i found that the main bearing is split and theres no white metal on the contact points
has anyone replaced this bearing? and do you have to buy the carrier with the bearing installed.
also what is the correct position for the flywheel, on the bis there are 4 big holes drilled to balance the crank, in the manual it shows the holes at the top at tdc but that would put the mass of weight on oneside of the crank, does anybody no why.
meuton
bearing
« Reply #1 on: August 26, 2007, 09:33:43 PM »
Hey Pedro
That little B*gger went three times on my BIS engine before i converted over to needle roller bearings instead, you can get them form any Piston and components type shop for around £35 I think off hand and the newer ones have an extra oil hole or too to help with the massive wear problem and then melting that you have encountered through oil starvation.
Cheers Doug
Its slow but it does it in style !!
Crankshaft Bearings
« Reply #2 on: August 26, 2007, 09:45:28 PM »
I'm gonna be rebuilding an anegine in a couple of months and although the aircooled dont suffer as much from liner wear I think i'll give that a shot, its a very cheep design!
Crankshaft Bearings
« Reply #3 on: August 26, 2007, 09:52:06 PM »
Thanks for the advise Doug, did you change the front as well? are they the cage type that just a press in.
Crankshaft Bearings
« Reply #4 on: August 27, 2007, 09:19:33 AM »
the manual is right. its so that when its spinning the weight on the one side helps "throw" it around. Its very important you put it on right as i did'nt on my first one and it was lumpier than my granmas home made custard :shock:  as for the bearing they  come as one hole unit as i just replaced mine......did'nt know about the needle roller one though?
Crankshaft Bearings
« Reply #5 on: August 27, 2007, 10:28:44 AM »
Cheers Mate, thought i'd just check. could'nt see how you balanced the crank with all that weight on one side.
meuton
« Reply #6 on: August 27, 2007, 10:03:35 PM »
Pedro
Yes i changed both ends to be on the safe side and when over at my parents i can see if if i have the invoice for them and maybe even the drawing for the dimensions if your lucky although the job was done about 7 or so years ago.  the bearing are pressed in with an interference fit watching carefully on tollerences not to crush the housings
cheers Doug
Crankshaft Bearings
« Reply #7 on: August 27, 2007, 10:45:23 PM »
That would be great if you still have the info, i  bought another engine 18 month ago, so i shifted half the garage to get to it today, thought i check the rear bearing on that and its exactly the same no white metal and split so that was plan 2 up the spout. so iv'e got two in pieces now,
there seems to be nothing wrong with the oil seal its not torn or frayed and is flexible, the only thing i can think is of is that with the excessive movement of the crank was letting oil out of the seal, i'll still replace it thow.
plan 3 is see if i can get the rear bearing tomorrow so i can get it back on the road for the weekend, and then rebuild the other with the needle bearing mod.
Crankshaft Bearings
« Reply #8 on: September 09, 2007, 09:02:13 PM »
Click on the photo's to enlarge
the tables set, i decided to go with Dougs mod needle roller bearing on the rear at this time and will get to replace the front in the future, it was the only bearing that was in good condition,  probably because its not carrying as much weight (flywheel) this is it installed in the bearing carrier.
installed the new big end bearings to complete the bottom end.
now to the front end and new timing gears and chain.
meuton
bearing
« Reply #9 on: September 09, 2007, 10:06:03 PM »
hey Pedro
the bearing looks great, best bit is the high pitched whine it gives as u rev up lol
cheers Doug
Crankshaft Bearings
« Reply #10 on: September 10, 2007, 06:40:47 PM »
should sound like a 2 cyl PORSCHE 356 then :lol:  :lol:  :lol:
Cheers Doug.
