Author Topic: fuel sender  (Read 3777 times)
dave.126
fuel sender
« on: August 23, 2007, 08:58:48 PM »
just a quick question,my fuel gauge isn't working on my bis,hopefully its just a wire off or broken but i just wondered if the senders are prone to failure and if there still available :?:  :?:
fuel sender
« Reply #1 on: August 24, 2007, 09:37:53 AM »
THE ANSWER IS YES AND YES
fuel sender
« Reply #2 on: August 24, 2007, 09:38:53 AM »
Mine works when it wants to.  Ithought it didn't work and then all of a sudden it leapt into action!
fuel sender
« Reply #3 on: August 24, 2007, 09:42:54 AM »
they stick in position and when you give them a good bump they free up for a while if you run the tank down they stick there and sometimes if you fill up the tank they stick there , its a lottery but you get used to it and can normally work out whats in the tank by the mileage .
meuton
sender
« Reply #4 on: August 24, 2007, 11:07:02 AM »
yeah i think mine is well stuck to the bottom of the tank too, as when i used to run it you had to guess how much fuel u had, i kept a spare gallon in the front boot
cheers doug
Its slow but it does it in style !!
fuel sender
« Reply #5 on: August 24, 2007, 01:58:29 PM »
usual test for the fuel tank rheostat unit is to remove the wire from the unit and ground it. The gauge should then shoot up to full, which proves the tank unit is faulty.
fuel sender
« Reply #6 on: August 24, 2007, 05:41:52 PM »
yep. mines gone too, have a new one on stand by :wink:
dave.126
fuel sender
« Reply #7 on: August 24, 2007, 08:03:05 PM »
well i guess that answers that then...cheers chaps...by the way how many miles do you get to the tank on normal driving?(roughly)
phreak97
  • Niki!
fuel sender
« Reply #8 on: August 25, 2007, 03:23:34 AM »
mine's air cooled, but it'd be the same wouldnt it? my fuel gauge waves around alot when its at the top half of the tank, steadys again once it gets down to about half.. should i trust the gauge?
phreak97
fuel sender
« Reply #9 on: August 25, 2007, 06:10:15 AM »
trust polish electrics? are you mad?........mine works ok but i always use my trip counter,its amazing how fuel cnsumption varies.....in the rain i can get 145ish before the car is right down in the red,dry im lucky to get 120......i think a bis is better than that because they are the worlds first water/petrol hybrid  :cool:
Utterly-Butterly
    • http://www.mcneice.net
fuel sender
« Reply #10 on: August 25, 2007, 08:06:57 AM »
remove the carpet on the near side footwell which forms the innerwheel arch as that is were the fuel sender wires connect, sometimes they tend to go a bit green (mouldy coloured) and a good clean usualy set things going again, goes for temp gauge as well.
phreak97
  • Niki!
fuel sender
« Reply #11 on: August 25, 2007, 09:43:23 AM »
lol, my friends goes about a hundred k's with the petrol light on, is that normal or broken?
phreak97
