Author Topic: really weird stuff, wheels locking from clutch?  (Read 4075 times)
phreak97
  • Niki!
« on: August 21, 2007, 02:46:49 PM »
i have discribed the problems i've had at the end of the thread here http://fiat126club.co.uk/forum/viewtopic.php?p=13983#13983
and id like to continue talk abut it in this thread, so my progress thread doesnt get too far off topic.
i dont think it's the engine overheating and siezing, the first time it happened the car had been sitting for an hour or so and it locked up reversing out of the driveway. the clutch always makes clunky noises when it's at its slipping point, taking off from a standstill. i know the gearbox is stuffed.. third wont go in unless im rolling, accelerating pops it out and produces bad noises of gears spinning against each other. second crunches in, shot synchro maybe. the clutch does the clunky thing, and all gears pop out occasionally (except third since that always does).
if the synchro bits for second are anything like what they were in my morris, then they could easily be getting into the gears.. but the last time it locked up, it was definately when i put my foot down on the clutch. and that should also rule out the engine.
what happens if the clutch gets pushed too far? can the clutch sieze?
i think this is what happened: i was in first going fairly slow, i went to change to second, and somewhere in that change it locked, i dont know what gear i was in then, i probably took off in first again, then when i put my foot on the clutch to go to second again, it locked, i released the clutch and it continued rolling, i pushed the pedl in again and it locked, i then stopped the car, reselected first, and drove back down my street into my driveway in first, slowly. i got in the driveway, then acting on impulse thought, what the hell, and took it out for a drive, using my regular driving style, not the cautious one, and i did a lap around two blocks without a problem.. so again, that kinda rules out the engine.
i have been trying to double declutch second gear since i think the synchro is dead, it has only done it since i started that.
how the crap can pushing the clutch pedal lock my wheels? how is that even possible??
phreak97
« Reply #1 on: August 21, 2007, 03:50:24 PM »
take the engine out and reinstall paying loads of attention to the clutch alignment when reconnecting , see what happens after .
« Reply #2 on: August 21, 2007, 04:47:57 PM »
big boots hitting the brake at the same time.............. :lol:
Maddog
« Reply #3 on: August 22, 2007, 12:58:19 AM »
your box sounds really fubar,
 it is possible that the clutch is failing to disengage sometimes, but if your engine is running this would cause the car to take off, not for the wheels to lock.
  probable cause is that the gearbox input shaft is moving about when you press the clutch causing your minced gears to lock up, get your hands on a decent box and swap it over.
Richie
phreak97
  • Niki!
« Reply #4 on: August 22, 2007, 12:54:30 PM »
locking minced gears sounds likely. niki boxes are hard to find here, theyre all in fiat 500s, i think ill take both boxes i have to a mechanic and get him to do a rebuild as best he can.
phreak97
Maddog
« Reply #5 on: August 24, 2007, 12:13:46 PM »
just a thought, double check that the clutch cable or gear selector cable isn't fouling the handbrake cables since you have had the box out, and check that everything is done up properly.
 also you could drain the oil and look for any bits of metal which would confirm the g/box internals being minced.
I would expect any box in which the internals had locked to be very mashed and not that likely to be at all driveable,
 if you can't get your hands on a good 2nd hand box then why not strip your old box and familiarise yourself with it, you may be surprised at how easy they are to work on and DIY rebuild
phreak97
  • Niki!
« Reply #6 on: August 24, 2007, 01:29:56 PM »
yep, im planning on stripping it, but the manual says i want a torque wrench.. how necesary is that?
i took the car out for a drive again lat night, and it seems every time i push the clutch in when moving in reverse it locks up, it did it every time without exception. i ended up having to reverse then push the gear stick out of gear without the clutch before i put the brakes on.. it was the only way to get out of my park. there was occasionally a light grinding noise (nothing major, or really loud) from the clutch when taking off in first, however it has not locked up in a forward gear again. the clutch is very bumpy, taking off from stationary is very shuddery, im thinking among other things, the clutch is probably completely buggered. it also feels like the back end isnt rolling smoothly, so the diff is probably dead too. i dont think i could have picked a worse box, the only gear which actually works properly is first, second does once youre in it, but i think the synchro is dead, fourth whines, and third seems stripped, and is useless.
but yes, do i need a torque wrench when im putting the box back together?
fairly disappointing that my replacement gearbox is so horribly shot.
phreak97
Maddog
« Reply #7 on: August 26, 2007, 04:26:22 PM »
you don't need a torque wrench as the only nuts are the ones holding the casings together, nothing too critical as long as they are tight you'll be fine
phreak97
  • Niki!
« Reply #8 on: August 26, 2007, 11:09:20 PM »
excellent, however now im doing the clutch too.. so maybe i should get the wrench anyway?
phreak97
Maddog
« Reply #9 on: August 27, 2007, 10:33:29 PM »
jerky would be an apt description of a 126 clutch in good working order, why not sort out your box before doing/buying anything else that you may not need.
  after letting my grey matter clunk and grind away on this it may be more likely that a loose, bent or broken selector fork is causing your oddly behaving box, the selector forks are held onto the selector rails with a bolt and if this came loose it would allow for a gear to be in the wrong position on the main or idler shaft whilst another was selected hence locking your box up solid.
I dont have a manual for a 126 but if you do then have a look, it should have a diagram showing the selector forks, possibly 3rd gear? as you don't seem to be able to select this at all. it may mean that the rest of the internals are OK except for the synchro which gets selected whilst still in another gear
you dont need anything to strip the box, best to know what the problem is before spending money, you  may end up just getting another 2nd hand box anyway
phreak97
  • Niki!
« Reply #10 on: August 27, 2007, 11:16:16 PM »
well.. i wasnt going to buy anything until i knew what the problem was anyway. the gearbox i've been using has broken the casing up by the speedo connector. im going to use the one that came in it, it just has a worn gear, and maybe a worn diff, but i doubt it. other than that, it's working. i also still think ill get a new clutch, i dont want to take the gearbox out again, and the clutch isnt just jerky, it really feels stuffed.
phreak97
Wozza
« Reply #11 on: September 01, 2007, 06:00:37 PM »
Just an afterthought really mate: Pay particular attention to the clutch release bearing,(the conical thrust bearing with two lugs on it, that sits on the end of the gearbox input shaft.). these can be fitted the wrong way around and play hell with the rest of your clutch mechanism !. I know cos i had to strip mine down a second time last time i had them apart :roll: . The two lugs should sit tight against the clutch release fork as you clip them in top and bottom. thought i'd better warn you, cost me about two hours more work.
phreak97
  • Niki!
« Reply #12 on: September 01, 2007, 11:07:46 PM »
haha, ill keep that in mind, thanks:P i took the two gearboxes in to a mechanic and told him to make one good box ot of the two, and to let me know if he needs any extra parts.
i really dont have to to fix it myself at the moment, and i want the car going asap.
phreak97
