Author Topic: Kingpin problems  (Read 4594 times)
jammy
Kingpin problems
« on: August 20, 2007, 01:13:28 PM »
Hi, i wonder if you could help me out, i have embarked on changing my kingpins after it failed its mot. I have got myself a haynes manual but it only covers upto 87 and mines 89. I have already had issues with the change as it looks different from the haynes description. At the base of the existing king pin housing is a disc with 2 holes in it, i have no idea what to do from this point and im close to scrapping it  :sad: .
PLEASE HELP !  :sad:
dave.126
Kingpin problems
« Reply #1 on: August 20, 2007, 02:02:47 PM »
hi chap,,i take it it failed on excess play in king pins,,,sorry if this is a stupid suggestion but did you try greasing them first,as a tester very often a king pin only just fails and is usualy down to lack of maintainance and a few pumps with the grease gun is more than enough to bring them back into limit...sorry if you've already tried this.. :D  :D  :D
Kingpin problems
« Reply #2 on: August 20, 2007, 02:07:07 PM »
Changing the kingpins can be a tricky job on the 126 without the correct tools. Do you have the special reamer which is required for this job?
jammy
Kingpin problems
« Reply #3 on: August 20, 2007, 02:44:38 PM »
yeah, i tried greasing and ive gotten hold of a 5inch reamer. The biggest problem ive had is a metal tube that surrounded the rubber bush that connected the shock, but once i removed it the manual says to hammer the kingpin out from the top, ive tried but it just wont budge.
If photos would make it easier i can oblige, and thx for your replys so far.
Kingpin problems
« Reply #4 on: August 20, 2007, 05:05:41 PM »
just buy new ones.....reaming kingpins on a 500 or 126 is ok if your on the moon and have no access to new,treat yourself,they are well cheap as well
jammy
Kingpin problems
« Reply #5 on: August 22, 2007, 01:22:57 PM »
you mean buy the complete units instead of just the pins ?, this is an option but me being a mechanical noob ill need to know how to get the existing ones off the track rod ball joint ? any advice as ive twisted, hit, swore at it and on occasion cried at its will to stay attached.
Kingpin problems
« Reply #6 on: August 22, 2007, 01:43:39 PM »
I had a similar problem a few years the bush was shot, so I managed to get a hacksaw in the centre of the bush cut outwards through the bush in two parts (180 degrees) and it came out!
If you do it this way make sure that you can get the new bushes first.
Kingpin problems
« Reply #7 on: August 22, 2007, 02:25:55 PM »
i've done a set of kingpins for my 500
(i'm using the standard 126 kingpins)
Theres a roll pin going through the centre swivel section.
After that a good bit of abuse from a mallet will clear the kingpin, you will have to be brutal with it. Be careful though as when attacking from the top so you dont mash the old bush as well as the pin. Find a punch that is narrower than the kingpin and you shouldn't have any issues.
Having said that, for the time it took me to remove the suspension bush, remove the kingpin, remove the kingpin bushes, replace them, ream them and re-install the pin, I would rather have bought a replacement set, they're not expensive and you can pick up a set with 2 grease nipples, improving their longevity.
Bit of advice from experience!!
Michael
jammy
Kingpin problems
« Reply #8 on: August 22, 2007, 04:57:18 PM »
ok, after your sound advice fellas im going for the full replacement, but im still struggling to get the bloody thing off the car due to the ball/socket on the trackrod, any ideas how to get it off ?
And ive found these
https://ssl.kundenserver.de/shop.fiat500126.de/indexa.htm
^^ is that what i want/need for a 89 126.
thx for your patience guys
Kingpin problems
« Reply #9 on: August 22, 2007, 05:04:32 PM »
the track rod end vcan be seperated in two ways,the first is easy with a track rod end splitter,the second is also easy but requires some finesse with a 2 pound engineers hammer,undo the nut,run it up and down the threads a few times with some lube,then when thats nicly freed up,smack the track rod end with the hammer,not the thread,the idea is to shock the taper apart,3 or 4 hits usually does it,then when its free you will be pleased that you have freed off the nut as it will just turn the shaft if not....have fun.... :cool:
oh.when you have done all this and replaced the kingpins you need to get the tracking done
Kingpin problems
« Reply #10 on: August 22, 2007, 05:05:39 PM »
looks like part 04013/A is the one that's required.
it will make the job so much easier!
are you using a balljoint separator to get the balljoint off? Usually dead easy?
jammy
Kingpin problems
« Reply #11 on: August 22, 2007, 05:11:48 PM »
never heard of a ball joint seperater lol, i could always try beating it to death like dave says but knowing my luck ill probbo bend the bloody rod lol.
Kingpin problems
« Reply #12 on: August 22, 2007, 05:13:29 PM »
no need to beat it to death,2 or 3 judicious twats will sort it.......
Kingpin problems
« Reply #13 on: August 22, 2007, 05:23:37 PM »
« Last Edit: June 25, 2014, 10:16:35 AM by ChrisRLewis »
jammy
Kingpin problems
« Reply #14 on: November 27, 2007, 08:13:45 AM »
hey guys, sry it took so long to get back to you all. But its good news, It flew through its MOT after i replaced the whole steering knuckles and braking cylinders. Im impressed with the steering now (light as a feather) and i have actually gained brakes !!. Just want to say thx for your help fella's.  :D
