Author Topic: Fitting a Webasto Style Sunroof  (Read 11929 times)
scottisbell
« on: August 19, 2007, 08:49:15 PM »
Hi Everyone,
Has anyone ever had a full length fabric sunroof fitted?
By that I mean to a car which didn't previosly have one.
Does anyone know what cost the cost would be to have a brand new one fitted.
Or how much work is involved in fitting from a donor car?
I love the idea of fitting one to my BIS.
Scott
« Reply #1 on: August 19, 2007, 09:12:45 PM »
have a look at my yellow 126 in the garage section , someone had a similar idea with this car but just added to the comedy value it now goes at 60 laughs an hour!!
Bruce
« Reply #2 on: August 19, 2007, 09:22:13 PM »
I put one on my DeVille, and I've got one to put on my Bis.
The Devilles sunroof was rusty and rotton so i just made the hole bigger and fitted the webasto, it was great, so good in fact i got another fo rmy bis. I just used a pair of tin snips for the deville, think the best way for the bis is to get a nibler.
Try and get a second hand one if you can and fit it yourself; the fist one i used was off an old Subaru coupe, the one i am using for the bis is off a Mini estate (a real mini, not one of those stupid BMW things).
To get one new and professionslly fitted would cost heaps.
Sorry no pictures.
scottisbell
« Reply #3 on: August 19, 2007, 10:31:18 PM »
Thanks Guys - bis 13, that is one crazy car!! Love it - but perhaps a little too extreme for what I was thinking of.
It sounds like it's a reasonably easy job? I'm no mechanical genius but not I'n not an idiot either and sure I can cut the hole no problem.
The only bit I'm not too sure on is the actual attaching of the sunroof frame to the cars roof, are there screws /pop rivots or something into the roof through and then covered by a flange on the sunroof frame?
I think I need to see one on the car. (if anyone has pictures, would be much appreciated)
I figured that brand new might cost more than the car was worth!! and that DIY might be the option, noticed a couple of second hand webasto's on ebay at around a £100 in recent weeks so if I can get a bit more info on the procedure I think I'll go with the idea.
Regards,
Scott
« Reply #4 on: August 20, 2007, 07:34:47 AM »
i have one here in bits in need of restoration,complete with pattern for the hole,it was complete but i pulled it o bits to cure rust in the metal supports areas...all second hand ones are prone to rust underneath the vinyl.
yours for £75.00 plus post
scottisbell
« Reply #5 on: August 24, 2007, 09:39:25 PM »
Thanks for the offer of the sunroof but I think I'll wait a while, I'm sure it's all fine but I'd prefer to see one before buying and plus I've just shelled out for Alloys - I think if I spend another lump of cash the missus will go crazy, I've only owned the car a month and every week I seem to find something to buy for it!!
Regards,
Scott
Bruce
« Reply #6 on: August 24, 2007, 10:55:52 PM »
the roof is fixed in position with a combinationof bolts, screws and pop rivits; the front part is pop rivited in place, as is the mount for the wind deflector that is on the inside directly underneath. the sides which consist of 2 pieces each side, with a trim on the top and a channel inside are held in place by countersunk screws and nuts, the back is bolted through as this is under tention when the roof is closed.
Bruce
« Reply #7 on: August 24, 2007, 11:04:55 PM »
Here is a link to the Wabasto website http://www.open-air-feeling.com/index_en.php the one you want is called the Hollandia 400
rys
Re: Fitting a Webasto Style Sunroof
« Reply #8 on: July 20, 2010, 08:47:43 AM »
has anyone picture of fiat 126 with hollandia 400 sunroof?
my sunroof shop said that hollandia 400 probably does not fit to 126, however bing13 as well as bruce says something different :)
RSPSTEVE
« Reply #9 on: July 20, 2010, 01:48:55 PM »
I had one done , pics in my 126 thread http://club126uk.co.uk/smf/index.php?topic=4556.0 , £150 off ebay , 350 ish to have it retrimmed in everflex and fitted , so about £500 all in, not cheap but looks lovely and well worth while with the current weather we have had in Essex  [-/
Ps the one to go for is the britax black frame , recomended by the roof man .
« Last Edit: July 20, 2010, 01:52:22 PM by RSPSTEVE »
rys
« Reply #10 on: July 20, 2010, 04:11:37 PM »
britax is the same as hollandia 400?
did you have to adjust the "frame" of sunroom or the size of roof was enough to cut the hole and fit the sunroof?
rys
« Reply #11 on: July 20, 2010, 04:18:18 PM »
I did some reseach using uncle goole and I found out
(1) britax is not the same as holladnia by webasto.
(2) Hollandia 400 dimenions in inches are 32.8 X 44.5
(3) Britax as available in two sizes that could fit to Fiat 126 - 35 X 27 OR 35 X 35
I guess that 35 X 35 is the perfect match - RSPTEVE - could you please measure yours?
« Last Edit: July 20, 2010, 04:44:12 PM by rys »
RSPSTEVE
« Reply #12 on: July 22, 2010, 09:46:38 AM »
I think mine is 35 x35(but will check ) its the biggest that would fit into my 126, it is actually out of a mini,the MGB GT one is the same .
The black frame is the best according to the guy who restores and fits them because the frame is in one piece, not 4 pieces ala webasto or weathershield.
jeffgainford
« Reply #13 on: October 12, 2016, 07:17:55 PM »
« Reply #14 on: October 12, 2016, 08:45:27 PM »
Hi Jeff, this post is 7 years old and Steve sold his 126 many years ago,
