Author Topic: how do i get the gear box oil drain plug out?!?!?!/!  (Read 3642 times)
phreak97
  • Niki!
« on: August 06, 2007, 04:58:48 AM »
WTF this thing is retardedly impossible to get out, how on earth am i meant to do it? infinite amounts of force by me seem to do nothing. im going to ruin it before it unscrews.
phreak97
« Reply #1 on: August 06, 2007, 09:43:43 AM »
What tool are you using? I use a 1/2" socket drive extention the wrong way around!
phreak97
  • Niki!
« Reply #2 on: August 06, 2007, 10:26:16 AM »
no.. the drain. it's a really big allan key. i ended up using a stilsons (spelling) wrench with a long metal pipe on the handle before i got enough torque for it to move.. insane.. wrecked the end of the thread by the wrench biting into it, but that be never gets used anyway, the plug doesnt go in that far. to fill the oil i used a large drink bottle (soft drink/soda style) filled with water, and a rubber pipe jammed into a hole drilled in the lid, so the pipe went all the way into the bottle, filled the bottle with oil, put the other end of the pipe in the filler hole, then rolled the rear wheel onto the bottle, left it till the bottle went down, refilled the bottle, and the gearbox was full second try. i used 20W/50 oil like i read here.
phreak97
« Reply #3 on: August 06, 2007, 02:41:01 PM »
funny you say that, cos i read the haynes manual and it also said use engine oil, but i also heard that, that was a bad idea and you should really use the proper gearbox oil :???:
Paul Clough
« Reply #4 on: August 06, 2007, 05:02:16 PM »
I struggled with the drain too... Luckily I had the box out so just took off the top cover and tipped it out!!
I filled up with decent gearbox oil though.... not sure I'd use engine oil?
Its a What?
phreak97
  • Niki!
« Reply #5 on: August 06, 2007, 06:05:08 PM »
well too late, it has engine oil in it. i read it here, so i did it. plus gear oil would have been harder to squeeze through the pipe. in any case, im using this car to learn on, if it doesnt work out, ill rebuild the gearbox that used to be in it.
phreak97
« Reply #6 on: August 06, 2007, 06:14:40 PM »
its engine oil guys....................hypoid will destroy the syncromesh hubs....................use a 20/50 or such.......
« Reply #7 on: August 06, 2007, 06:27:58 PM »
Checking all workshop manual and it comes up with the following:
Aircooled - SAE 80W/90
BIS -  SAE 75W/90 Semi-Synth
Dave where did you get your info to use engine oil? I know you are well up on 126 motors and you are probably right.
Chris  :)
« Reply #8 on: August 06, 2007, 06:34:08 PM »
i honestly cannot remember,but like morris minors etc they def use engine oil,hypoids are for heavily taxed gear trains,i have used engine oil in all my 500's and 126 boxes,i'll check through my dead sea scrolls to see whats wat,but i would not use a hypoid in a 126/500 box.
« Reply #9 on: August 06, 2007, 06:37:20 PM »
just checked my haynes manual and it states 15/40 duckams hyper grade.............
« Reply #10 on: August 06, 2007, 07:07:33 PM »
I've benn running 20/50 in the box for about 4000 miles and its been fine for me
banjomandolin
Gearbox oil drain plug.
« Reply #11 on: August 06, 2007, 08:26:43 PM »
For removing the gearbox drain plug you will find that the hexagonal head of an 11mm bolt fits nicely. Then screw two locknuts on the threaded shank or use your stilsons on the threaded shank.
Banjo.
John Clark
phreak97
  • Niki!
« Reply #12 on: August 07, 2007, 03:20:33 AM »
ah, never thought of putting a bolt in it.. it's all done now anyway.
i like the idea of the magnet on the plug to stop all the metal filings from floating aroud into the gears.
phreak97
