Fiat 126 Chat
where do i put the ballast resistor
Pages: [
Topic: where do i put the ballast resistor (Read 3270 times)
on:
August 04, 2007, 10:45:44 AM »
i need to wire up a ballast resistor as i am switching to a twin spark coil could anyone explain in basic idiot talk for me as to where i need to wire it in as i dont have a clue . is it just wired in on the 12v cable from the battery to the coil or is it something else either way help please!
phreak97
Niki!
Reply #1 on:
August 04, 2007, 11:18:20 AM »
from my experience, yep, between the battery and the coil. but probably wait for a second opinion, as im not so confident, i have only worked on about two coils.
phreak97
Idle Steve
Member
Reply #2 on:
August 04, 2007, 07:39:33 PM »
On the Bis it is incorprated within the wiring loom as a resistance wire as far as I am aware on the live feed to the coil.
http://img77.imageshack.us/img77/2739/newuntitled1ul3.jpg
You must have an old Bis loom kicking about which you can pull apart, Mick?
The wife calls Him "Cecil"
Reply #3 on:
August 04, 2007, 10:57:13 PM »
well on the bis it has a red wire in the center then a grey/black wire loop and then the same exits what is the grey/black wire connected to?
ignore that i have been talking rubbish
phreak97
Niki!
Reply #4 on:
August 05, 2007, 02:36:37 AM »
is the whole wire resistive? or is there an obvious resistive part?
phreak97
banjomandolin
Ballast Resistor.
Reply #5 on:
August 06, 2007, 08:36:12 PM »
Do you have the Haynes Automobile Electrical Manual. ?. P. 86 & 87 explains it all.
Banjo
John Clark
phreak97
Niki!
Reply #6 on:
August 07, 2007, 03:21:09 AM »
nope, im trying to get one.
phreak97
totyfox
Member
hi
Reply #7 on:
December 14, 2007, 03:03:03 PM »
does any one have the manual for engine of 126p? plz help
Pages: [
Fiat 126 Chat
