Author Topic: engine dies before accellerating  (Read 2779 times)
phreak97
  • Niki!
« on: August 01, 2007, 04:26:14 PM »
basically, when i accelerate from idle the engine dies completely before reviving (usually, not always, depends how fast i push the accelerator, harder makes it stay dead) and revving up, this happens in neutral aswel, and i can actually turn the engine off by just putting my foot down. i only know this happens when the engine is cold, but thats only because it's not allowed on the road yet.. it could be a constant problem. if i accelerate very slowly until the engine has got over its dead bit i can push it in faster after it has passed, its just the initial acceleration which doesnt work. i had this problem in my sigma a while back, but the mechanic fixed it, i had no interest in mechanics back then.
so what are my possibilities?
phreak97
« Reply #1 on: August 01, 2007, 06:05:42 PM »
have you been using the choke?
« Reply #2 on: August 01, 2007, 07:00:34 PM »
sounds like the engines suffering with a fuelling problem , have you touched the carb at all ? it may be out of adjustment , need a clean out , or your float is perforated and so lets in too much fuel so that the fuel air mixture is going crazy and makes the car die.
phreak97
  • Niki!
« Reply #3 on: August 02, 2007, 03:20:17 AM »
yes the choke is adjusted correctly,as a fan of older cars, i've been using chokes for most of my driving life.
i have never taken a carburetor apart, and only very briefly know how it works.. what should i know before pulling it out? and what am i looking for? im generally very good at figuring out how things work once i have them apart, but i still want to go in there with a little bit of knowledge. what should i not do incase i mess something up? and how do i go about adjustment, given that i have no tacho or anything?
the car also hasnt been run in a few months.. could the fuel have gone bad? does fuel go bad? it had a full tank when i got it.
phreak97
« Reply #4 on: August 02, 2007, 02:02:20 PM »
No offence intended, we have come accross some special cases on here before!
« Reply #5 on: August 02, 2007, 02:23:50 PM »
I would go along the route of removing the carb and giving the jets a good clean out. Use one of those aerosol carb cleaners and an airline. Do you have a manual?
And yes petrol does go off! Put some fresh stuff in, keep the old petrol for cleaning bits and pieces
Forgot to add put an inline fuel filter on, it does help!
phreak97
  • Niki!
« Reply #6 on: August 02, 2007, 03:30:56 PM »
i didnt mean to sound offended, im sure plenty of people would not even realize a choke existed.. especially given the odd positioning.
no i dont have a manual, but i think a guy on here is going to get me one, so i should be ok once i have it. ill ask at my local auto place about the  aerosol cleaner.. and ill drain the fuel tank and chuck in a bit of 98 octane.
when i get a manual ill ackle the carb, i know i can wreck settings in there, so ill hold off for now. oh, and it already has an inline fuel filter.
phreak97
« Reply #7 on: August 02, 2007, 04:26:58 PM »
phreak97
  • Niki!
« Reply #8 on: August 02, 2007, 04:43:36 PM »
excellent! if i dont get ontothe gearbox tomorrow i might give the carb a try.
phreak97
