Author Topic: rear end noise  (Read 2290 times)
rear end noise
« on: August 01, 2007, 08:16:50 AM »
I've found a new noise on the car and it's getting a bit louder.
It's a dull thud coming from the back end of the car every time I come off the gas a bit quickly.
I'm pretty sure the drive shafts and sleeves will be fine as they were replaced less than 2000 miles ago. It sounds like it could be gearbox mount or rubbr donuts at the wheel, but as i've never had anything like this go wrong yet, i'm not sure what it is!
Any ideas??
Michael
rear end noise
« Reply #1 on: August 01, 2007, 10:03:14 AM »
It may be the drive shaft bolts have come a bit loose?
rear end noise
« Reply #2 on: August 01, 2007, 10:37:29 AM »
does it do when reversing?? mine did,was rubber engine mount,an oily/sticky clutch didnt help the mount  either
rear end noise
« Reply #3 on: August 01, 2007, 01:30:45 PM »
i've checked the drive shaft bolts and the engine mounts - all tight. Inecedntally its a 500F with the aluminium bracket & spring, very solid.
No play in the gearbox mounts.
any drive shaft related problems usually make a juddering noise.
rear end noise
« Reply #4 on: August 01, 2007, 02:43:21 PM »
Haven't checked if it happens in reverse yet, I'll try that tonight.
Could it be a combination of a worn gearbox mount and a worn drive shaft spring allowing the 2 to make contact?
The more I think about it, the more i think its related to the engine over rotating due to a dodgy gearbox mount, which would cause a driveshaft to tap against the hub
