Author Topic: gearbox changeover, what should i know?  (Read 6782 times)
phreak97
  • Niki!
« on: July 28, 2007, 02:22:48 PM »
hi all,
basically my niki (fsm 126 air cooled) has a buggered gearbox and/or diff, so the guy who sold it to me gave me another gearbox and diff for free as untested. i have taken the cover off the top of the gearbox and turned things and the gears all look pretty good, the small one in the middle at the top is a little worn on one side, but it doesnt look worn enough to be an issue at all.
in short, i have never worked with a gearbox before, and i need to swap mine with this one. what do i need to do?
i was told i would need to take the engine out, but i had a look under the car and it looks like i might be able to do it leaving the engine in. what is the easiest way?
basically, i need a brief idea of what i should do to make the new (used) gearbox/diff happy in it's new home. and i need fairly step by step instructions on removing and replacing the gearbox/diff from the car.
i do have a pit i can put the car over if it will be easier.
phreak97
Maddog
« Reply #1 on: July 30, 2007, 12:51:41 AM »
a quick run through
raise the back of the car on ramps or axle stands,  chock the wheels
disconnect the battery -ve terminal. DO NOT FORGET THIS
support the gearbox on a trolley jack.
undo the speedo drive, clutch and gear shift cable at the gearbox,
undo the 4 bolts that secure each driveshaft to the hub, a good 6 sided 3/8 socket set will make this easier as the heads of the bolts are very close to the driveshaft
undo the 3 bolts that secure the gearbox crossmember to the car.
undo the 4 bolts that secure the bell housing to the engine and the two that hold the starter motor on, hold the starter motor up out the way with some wire. or unbolt the feed wire and remove completely
now lower the trolley jack and slide the box forward off of the input shafts splines,
refitting is the reverse, to get the splines lined up you can turn the engine over by a using a spanner on the crank centre bolt until it aligns.
some fresh oil in the box and your away
say 3-4 hours for out and back in if you encounter no problems, good luck.
Richie
phreak97
  • Niki!
« Reply #2 on: July 30, 2007, 02:16:32 AM »
excellent, that sounds easy as. thanks alot for that. now i just have to get myself something to put the rear end up on, and also a trolley jack..
is the trolley jack really necesary? i noticed i can carry the new gearbox (with drive shafts connected) by hand.. i might just be able to support the one in there with something and try to pull it out myself? i dunno.. maybe a bit risky with me being under it. ill see if i can get my hands on a trolley jack. my uncle had ramps to put his car on, i wonder if my auntie still has them stuck around the side of her house somewhere.
phreak97
« Reply #3 on: July 30, 2007, 11:01:40 AM »
you can always use a plank of wood (thick) and two helpers to take out the gear box , and use blocks to hold the engine . not very professional but its system d at its best . if you dont have ramps use any spare steel wheels you have to raise the rear up by jacking up and simply placing the wheels under each attached wheel .
phreak97
  • Niki!
« Reply #4 on: July 30, 2007, 12:31:19 PM »
blocks to hold the engine? i didnt know the engine needed holding either way:s
i think i might figure out a way to hold the gearbox on my own.. im good at improvising. i might be able to figue something out with a plank of wood and a scissor jack or two.. but im not going to try anything if i cant get it very stable. i can get ramps too, theyll either be at my aunties place or my cousins place.. either way theyre easy to get.
phreak97
« Reply #5 on: July 30, 2007, 12:54:43 PM »
if you are changing the gear box it is easier to pull the whole engine out anyway it only takes a few hours first time to pull it out and put it back again. and is the easiest way to work on these engines .do you have a manual? if not we will sort you out one and send it to you . mick
Maddog
« Reply #6 on: July 30, 2007, 04:04:08 PM »
you don't need a trolley jack but it makes the job so much easier, especoially putting it back in, it allows you to lift/drop the box by the little increments required to get the input shaft to line up,  trying to line up the splines and support the box at the same time is a pain even with a diddly little box like the 126.
  find someone to help you do this even if its just to help get the box aligned and pass you tools under the car/make cups of tea etc,
 if you want to take out the whole engine and box together the choice is yours but it takes longer, not really anymore difficult, having done the job I'd say not worth the extra effort, the only tricky part of fitting the box under the car is aligning the splines,
  oh! and filling it with oil, I use a brake bleeder kit that uses air from a tyre to pump the oil in, available from most motor spares shops for a few quid, it's quick and no mess.
 Richie
phreak97
  • Niki!
« Reply #7 on: July 31, 2007, 03:19:35 AM »
alright, i might see if a friend of mine will come around to help out.. ill also have a look at my aunties place when i go there, my uncle might have had a trolly jack aswel.
phreak97
phreak97
  • Niki!
« Reply #8 on: August 02, 2007, 08:32:28 AM »
well.. i got ramps, unfortunately i didnt get a trolley jack, but ill see how i go. do i need to support the engine? it looks like the only things holding it in are the gearbox mounts and the spring mount at the back of the car. is it a bad idea to let the engine hang down off that one spring? it looks like it could bend the metal in that area (on the car, not the engine). it would make it easier to put the new gearbox in if the engine were down on that angle though.
phreak97
« Reply #9 on: August 02, 2007, 09:34:42 AM »
id pull the lot out,with the engine out you can get to the box easier,and its easier to replace the engine to the fitted box after as well,you do need a trolly jack for this operation tho,a cheap one will do.
phreak97
  • Niki!
« Reply #10 on: August 02, 2007, 04:48:17 PM »
well.. i cant get a trolly jack. not any time soon anyway, and i'd like to try the changeover tomorrow. also, id rather not have to take the engine out.. i dont think my ramps are high enough for that anyway.
just realized the bit behind the rear bumper comes off so hight isnt an issue, but i still dont want to take the engine out if i an help it.. just more work.
ok, im taking the whole engine out now.. it does look to be easier now that i think about it more. things might be different if i had a trolley jack, but i dont, so engine out it is.
phreak97
phreak97
  • Niki!
« Reply #11 on: August 03, 2007, 04:08:37 PM »
well, it's all out. i have to figure out whats the best way of supporting the whole lot while i swap the gearbox.. should i just put the sump on the concrete? i took the plate off the top of the old gearbox, and it's pretty chewed up in there.. the "new" box is much better.
phreak97
« Reply #12 on: August 03, 2007, 05:21:01 PM »
put something like a bit of wood under it.
phreak97
  • Niki!
« Reply #13 on: August 16, 2007, 02:48:24 PM »
well, i changed it over, and the replacement box seems to have more issues than the original one. the original one worked, but had alot of play in first and reverse, and in the dif i think too. the new one sounds bad in reverse, but not first, and third gear is almost unselectable, and when selected, pops out easily. i have adjusted the gear lever position so that it pulls third in as hard as itll go, but it isnt far enough.. i think ill end up pulling both gearboxes to bits and boulding one back up in the original casing. having a manual at this point would be extremely useful. if anyone has a manual covering a late air cooled gearbox, id love to either buy it, or get copies of the valid sections. given my budget, a pdf sounds good for now, im already borrowing money so i can have working tyres aswel as food for the next two weeks.
phreak97
« Reply #14 on: August 16, 2007, 02:50:45 PM »
i am trying to get you a manual asap , when i have aquired one i will send it with the switches . mick
