Author Topic: bis in need of more help  (Read 3304 times)
elbisto
« on: July 27, 2007, 06:45:13 PM »
Hi Folks
having solved my exhaust problem and the car no longer smelling of petrol, I now have a few more problems, can any one help with any of these?
1. now that I have fixed the exhaust hole, it is now possible to hear the running noise of the car, and its not all good. When the car is in 3rd or 4th gear, but when you arent giving it many revs, or have the clutch in, there is a strange noise coming from the general engine area ( i cant be more exact as i have to be in 3rd or 4th gear and therefore on the road, it doesnt make the noise when idling in neutral). it is like a vibrating/light grinding noise that stop when you press the throttle. if anyone has heard of anything like this, any suggestions would great, sorry its very vague
2. stiff steering. the steering is very stiff!and makes a noise like a creaking old ship when you turn the wheel. the previous owner had the same problem and rectified it by greasing the king pins, is this the right solution? If so, do I have to remove the wheels/hub and brake backplate etc?I have a 126 haynes manual, but is the bis the same setup? and do i have to remove the king pins to grease them?
3. the camber of the rear wheels. they are leaning quite far out towards the top, so much so that its worn the tyres really badly on the outer edge. Another post here suggests that i need to lower the suspension - how would i go about doing that exactly? - but having checked the haynes manual it suggests that you ought to toe in the wheels, either by referring to your garage, or in an emergency (!)moving the rear suspension control arm slightly, on its elongated bolt holes. ( again not sure if this is the same on the bis). has anyone else had this problem, and fixed it using either of these methods?
hope someone can point me in the right direction and please excuse my technical ineptness
Paul Clough
« Reply #1 on: July 27, 2007, 08:42:59 PM »
:lol:
Hello again..
I have a few ideas but I'm sure you will get more...
1) This sounds like th ethrust release bearing on the splined shaft... It holds the clutch in place.
2) This sounds like iether the steering wheel cowling is dragging on the steering shaft, or the steering box is out of fluid (grease).
3) No Idea? sorry....
Good luck
Paul
Its a What?
« Reply #2 on: July 28, 2007, 09:54:26 AM »
1 could be anything,2 grease the king pins,nipples are easy to get at with a grease gun,3 positve camber is normal on bis and a/c,and because of the geometry will be more obvious when the car has been reversed.  :wink:
banjomandolin
Rear wheels camber and wear
« Reply #3 on: July 29, 2007, 11:28:19 PM »
No. 3. rear wheels camber and wear. The rear wheels do camber out at the top so not a problem.
          Front wheels with tyres worn on one side  have a habit of getting themselves swapped with the rear wheels and tyres when the vehicle is about to be sold. They aren't so noticable on the rear. They wear on the front because the steering geometry (toe-in) needs adjustment. A visit to Kwikfit is in order.
Banjo.
John Clark
banjomandolin
Gearbox removal & stiff steering.
« Reply #4 on: July 30, 2007, 12:04:20 AM »
More thoughts. The Bis doesn't have a steering box, it's rack and pinion, all enclosed in a rubber gaiter. You would have to remove the rubber gaiter to re-grease. Greasing the k/pins has to be the answer but you will only know if this is  effective if you see the grease squelching out at the joints. Jack up the car under the centre of the front transverse spring and remove the front wheels before you start the greasing operation. It allows you more access. Axle stands are also necessary for safety's sake.
             You can remove the gearbox without removing the engine. See the Haynes for the a/c sec. 3 Pages 53-55. The procedure for the Bis is the same except there is no torsion plate and the gearbox supports are different.
Banjo.[/u]
John Clark
banjomandolin
« Reply #5 on: July 30, 2007, 11:20:35 PM »
elbisto, hey, sorry about the last para. on the gearbox removal, it wasn't relevant.
Banjo.
John Clark
elbisto
« Reply #6 on: July 31, 2007, 01:12:07 PM »
thanks banjo, ill be giving it a go later in the week. I figured that last bit wasnt important.
I have just had the car pre mot'd and it turns iout my petrol tank is "disintegrating" in the words of the garageman, is this quite an easy swap?
banjomandolin
Petrol Tank Swap.
« Reply #7 on: August 02, 2007, 12:25:48 AM »
Elbisto,  That long filler pipe with 90 deg. bend in it causes a problem. Disconnect the clip which is behind the trim panel just behind the passenger seat and loosen the filler pipe's grip on the metal filler pipe section. Stick a trolley jack with a soft contact under the tank to be removed and then  undo the 3 tank support bolts. Then lower the jack until you have made enough clearance to disconnect the 2 fuel gauge elect. connections and 2 fuel pipe connections. Then you will have a wrestling match with the tank because the filler pipe is still connected but you will win in the end. You just have to be ever so slightly brutal. Empty any petrol left in the tank into your wife's Mondeo.. I hate to say this but re-installation really is a reversal of the removal. I found that sometimes you can get at the filler pipe joint clip (at tank end) from outside the car if you remove the rear left hand wheel.
Banjo.
John Clark
elbisto
« Reply #8 on: August 09, 2007, 06:59:36 PM »
sheesh
you werent lying about the filler pipe banjo, i thikn i have found my new worst enemy ( i found that removing the filler pipe from the car at the petrol cap eased things along)
tank swapped though, and very effective, the only problem is the fuel guage. When i took it off i took note of the position of the wires and which colour was rearmost, when ive reinstalled them, it doesnt give an accurate reading on the fuel guage( it told me it was full when id only put in 5 litres). Would this be because ive put them on the wrong way round? and why would they be wrong, when i noted the positions? Does it matter which way the connectors are facing? now that ive put a full tank in, it says it is now even fuller than before, so theres obviously something acccurate about it, but just not very
hope someone can advise. oh and if you say i have to drop the tank down to get at the connectors, ill be sad as it took me ages!
phreak97
  • Niki!
« Reply #9 on: August 10, 2007, 02:40:40 AM »
im guessing you swapped the the whole tank including the sender for the gauge? i dont know alot about fuel senders, and i have never seen a 126 one, but you have a working sender in your old petrol tank if you end up needing to swap them. depending on how it's designed, it could be possible that the sender can be put in both ways, and so the wires would probably need to go the other way around. i dont know enough to say it's safe to go swapping them to find out though (it probably wont do too much harm), wait for another reply if youre unsure.
phreak97
