Author Topic: BIS bumper brackets  (Read 1913 times)
nathan126
BIS bumper brackets
« on: July 26, 2007, 01:46:14 PM »
Hey guys! i need to do a bit of work around one of my front bumper brackets and in order to do so, i need to remove the bumper. I can see how to undo the main front Bracket frames, but how would you suggest removing the side screw-on plastic ones? as no normal screwdriver would ever fit in that gap. (Bearing in mind that i will put the bumper back on for originality sake)  :roll:
meuton
BIS bumper brackets
« Reply #1 on: July 26, 2007, 05:08:30 PM »
hey there
I simple used a screw driver using a large bit from a socket set i think or you could use one from an impact driver as they have larger bit ends.  Any decent screwdriver or socket set will have one big enough
cheers Doug
Its slow but it does it in style !!
BIS bumper brackets
« Reply #2 on: July 26, 2007, 05:10:48 PM »
the side rubber brackets fit to the car first,then the bumper kinda clips into them,undo the main brkts and simply pull the bumper off,the side rubbers stay on the car
nathan126
BIS bumper brackets
« Reply #3 on: July 26, 2007, 05:14:09 PM »
Oh right, cheers guys!
I didnt want to damage anything so thought it best to check first.  :D
