Author Topic: Doors and hinges  (Read 1930 times)
punkydog
Doors and hinges
« on: July 23, 2007, 07:43:30 PM »
Am I correct in assuming that the door hinges are not replaceable? The bottom hinge on the drivers door went all wobbly, at the door end, and began scraping on the wing. Looks like they are spot welded in when the doors are made. I have welded it up on the outside but the door doesn't close right Added to this the two threads are stripped on the door post so I will have to fit studs. I will have another play with it but there isn't much adjustment there, without all the washers put in the door drops a lot but the hinge pins are fine. The door was re-fitted after a paint job so shimming it to align correctly might have put strain on the hinges. This is on a 28k mile car - so do they fall off older/rustier ones?  Are the complete doors only available from Germany and are they all the same 126.1, 126.2 and Bis?  I assume the hinges come with them.
Cheers, Brian
Brian
Doors and hinges
« Reply #1 on: July 24, 2007, 05:22:08 PM »
well,what happens is this,the pin is supposed to be fixed in the small outer lugs/ears,just peened over,in real life,the hingepin does not get lubed,it then sticks in the wide door bit,so the whole door weight is taken on the two small 'ears',i fixed mine by using good pins from a PASSENGER door,it seems the pins wear but the hinge stay good,so a repair is possible,i fixed my drooping 40.000 mile drivers door like this,its as bad as new now LOL.....
