Author Topic: repairing rust without welding? seat spring replacement?  (Read 4359 times)
phreak97
  • Niki!
« on: July 22, 2007, 01:55:54 PM »
i have a little experience with bog (filler stuff.. dunno if thats an australian product name or what) but i have never done the paint, nor worked with a hole that i couldnt get to the other side of.
so, what i have is rust under the back window which has been filled and now swolen out again, it doesnt look to bad, and i have already sanded it back a bit and i think it will be easy to just add more bog then sand and paint. i also have a dent where the drivers door was over-opened, so theres no hole, but it has rusted because the paint was scratched off. i think this could be repaired by filling it and sanding it, but i dont know how i would go about making the bog stay there and not fall off. also there are holes on either side under the windscreen which have had sheet metal put in and then covered, but the bog has fallen off both. also i have a couple of holes next to the windscreen where a second aerial was added, no idea why.. but now i have holes to fill, and these are the ones i cant get to the other side of.
so can anyone help me with what and paper to use and what type of paint to go for, also how to do the holes? what i was guessing ws that i should hammer around the edges so that when i sand it flat afterwards theres bog overlapping the edges still. the only real hole is only a cm or a little more in diameter.
basically, i wouldnt worry too much, except i have to take it for a roadworthy test before im allowed to register it, and i hear theyre pretty comprehensive and will pick on almost anything. so i want to do the absolute best job possible..
also, i have four seats and only one has all it's springs in tact.. however i clearly only need two seats, so im happy to swap some springs around, if someone will kindly tell me how. i really couldnt get the good springs out easily, or at all, from underneath the seat.. and taking the upholstry off looked pretty difficult too. then once out, how do i get everything back in place so itll stay there?
also if anyone knows of anything common that will stop a 126 from passing, please let me know.
phreak97
« Reply #1 on: July 23, 2007, 10:50:31 AM »
it is possible to repair a none load bearing area with filler etc,but you need to cut back to good steel,then use isopon p40(a chopped matt filler) as a repair base,together with some alloy mesh....then finish with p38(normal filler)....stopper.....primer....more stopper and primer....then paint finish........but its easier to weld a patch in,get your self a MIG and have a go..... :cool:
phreak97
  • Niki!
« Reply #2 on: July 23, 2007, 12:29:11 PM »
hmm.. i think the hole is small enough to just hope nobody pushes on it really hard.. also im on a tight budget, and i cant afford any kind of welding equipment. i think it might be possible to use fibreglass there as another option aswel. the hole aside, what steps should i take when painting and what sand paper should i use for the filler and the painted area afterwards?
phreak97
« Reply #3 on: July 23, 2007, 12:42:55 PM »
once you patched up the hole with glass and  filler,use a very coarse grade production paper to get the correct profile,then drop down thro the grades of wet and dry,then use stopper to fill any small imperfections then use either a spray putty/primer to get a good finish with more flatting back,then go for it with the finish colour....that should get you a half decent job.
phreak97
  • Niki!
« Reply #4 on: July 28, 2007, 03:56:08 AM »
cool, thanks..
now about the seat springs.. is there an easy way to swap them out?
phreak97
meuton
« Reply #5 on: July 28, 2007, 01:17:45 PM »
hello phreak97
what i am about to suggest is not something i would do but you would be best purchasing "plastic metal" which is an enginerring filler used to repair demage to machines, casings etc, i used it once to give you some idea of its strength to fix a crack in a race engine block at the oil pressure outlet hole and 4 years later to my knowledge its still as good as new.  It is made up of special toughend epoxy mixed with real metal powder and a number of other stabilisers and strengthers It is made by a company called "DEVCON" so ifyou into a tool store and ask for "DEVCON PLASTIC METAL" you should get a tub which has hardener and the compound for around the equivelent of around £20 british and that will outlast the car and as said put it in with a little bit of small gauze mesh and flatten down afterwards
cheers DOug
Its slow but it does it in style !!
phreak97
  • Niki!
« Reply #6 on: July 28, 2007, 02:04:00 PM »
thanks, i might price some of that cos it sounds like it would be useful in other places too.
i repaired a seat today, it was quite easy and took me less than half an hour.
if anyone would like instructions, say so and ill post it here. it's more than i want to type if nobody wants to know, however im more than happy to if even one person is interested. i also think it would be very easy to replace the seat springs with something more reliable, such as pirelli webbing, or something similar..
phreak97
Maddog
« Reply #7 on: July 30, 2007, 01:05:33 AM »
don't want to sound like an old fart, but if it fails its roadworthy for rust its for a good reason, these cars ain't exactly tanks to begin with,
  cattying up structural points of a car is illegal in the UK, it is a criminal offence punishable by jail time, there have been cases of manslaughter braught against people who have done this then the vehicle was involved in a fatal accident.
  but more to the point, if you have an accident and your car crushes up like a tin can around someone you love (yourself included) because it only consists of rust and filler, how would you feel?
 small repairs like this would not be expensive to get welded properly, ypu can finish and paint them yourself to save money.
safe motoring,   Richie
phreak97
  • Niki!
« Reply #8 on: July 30, 2007, 02:07:03 AM »
they arent structural areas as far as i know, but they do go underneath the front and back window seals, and to get it welded would cost me more than i paid for the car. it most likely wouldnt fail because of the rust, but the inspectors here arent happy people, and im going to do my best to make the car look nice for them. that and i am already having to spend more than i can afford to get new tires, the car would be off the road for another six months if i were to get it welded, then the tow cost to take it to a workshop..
phreak97
« Reply #9 on: July 30, 2007, 10:54:04 AM »
the areas you describe are common problem areas , the front bottom windscreen rust is not on the a pillar so is not a structural repair same for the back botton windscreen where the metal rusts around the plastic water holes . just take out the glass and do a neat as you can repair not forgetting that the glass must go back in and make a good enough seal so that it does nt leak in the rain.
have fun repairing your car its a hobby and is meant to be pleasurable and stressfree if you cant weld your car have a mooch around locally you will always find someone who can , will, and has the equipment . and with subtle persuasion can get things done for next to nothing , if your skint get a welder to do your car in exchange for labouring , but dont do sexual services .. unless its a she and is a stunner... even in australia you will find it works you will find people own welding gear and its sitting in a garage doing nothing its only when you mention welding that it becomes apparent.
phreak97
  • Niki!
« Reply #10 on: July 30, 2007, 12:26:03 PM »
yeah, that's true, and i have every intention of getting it welded eventually, and also learning to weld myself.. but right now i really want to get it on the road.. even if the filler is only in there for six months before it is cut out..
the guy i bought my topolino from can weld, and i think he might be ok with teaching me to weld too.. however he isnt back for another month, he went to italy for the fiat 500 launch and is staying with friends or family or something. my topo is out of service at the moment too.. im REALLY looking forward to getting that one fixed too. but niki is going to come first just because i can work on that myself without worrying.
phreak97
Maddog
« Reply #11 on: July 30, 2007, 04:42:11 PM »
sorry, didn't make it clear that I meant the area around the front screen, the bit at the back of the car is not such a problem.
  from your description It would fail a UK MOT as it is a part of the front bulkhead, you could always take out the screen and prepare it yourself, then you would only be charged 1-2 hours labour to have it welded.
 Im not being judgemental, I've been a student running about in rustbuckets with dodgy brakes and steering and I got away with it but I've also had friends who weren't so lucky,
 if you total up the cost of glassfibre, filler, paint etc iit wouldnt cost much more to weld it now and then fill and paint it later.
if the inspector suspects that a structural part has been filled, he will just knock a hole in it anyway with his MOT screwdriver
Richie
« Reply #12 on: July 30, 2007, 06:27:43 PM »
every car you look at on ebay has a small amount of rust on this area but they all have mots , every car i have has rust in this area its a very very common problem but its not a load bearing area ,the area that rusts is the lip where the windscreen sits .i have taken 5 cars with the same problem for mots and not once encountered any sort of comment or examination about it . and if you take a car for an mot and the examiner takes a screwdriver to your vehicle he must legally do so with you present did you know that?
« Reply #13 on: July 30, 2007, 06:37:22 PM »
in the end its up to you,its your car,better to weld but easier /cheaper to fill sometimes.....enjoy your hobby and try and get your nikki road worthy......there are plenty of nut and bolt restos that have just gone to the scrappy,a rolling resto is best if you have a limited budget/skill level.
phreak97
  • Niki!
« Reply #14 on: July 31, 2007, 03:12:46 AM »
only problem with taking out the screen is the seal has been under the australian sun for a fair while.. it's doing its job now (mostly) and is secure, but i dont think it would go back easily if it were taken out. that and i've tried to remove front and rear windows in wrecks before and never succeeded without cracking the windows. it is simply not a job i am willing to do myself. i dont know about over in the uk, but from what i've seen here, rust repair is incredibly expensive. my valiant had a quote done for cutting out the rust in the bottom of the doors, (one small patch on each door) plus one spot under the rear window, and it came to AU$1500 (www.xe.com for currency conversion). i simply cant afford to have such things done right now. you must also remember i am running four cars, this is not my only one, it's just my current favourite every day car, so i cant devote all my money to it, at least not until it's on the road. my current every day car is a morris 1100 s, and the brakes are in desperate need of attention, however first priority has to be eating lunch today, then paying to get out of the car park after work. money is a fairly large issue here, and im pretty sure a tin of bog wont be as expensive as a professional welding job.
phreak97
