Author Topic: WOW door handles are hard to remove....  (Read 2038 times)
phreak97
  • Niki!
« on: July 22, 2007, 09:40:34 AM »
it seems like the only way to get to the second nut is to partly remove the window runner... is there a better way? i need to swap the locks which i actually have keys to into my working niki..
phreak97
punkydog
« Reply #1 on: July 23, 2007, 07:18:35 PM »
If you release the bottom of the runner by removing the large headed screw on the side, you can bend it out of the way. You will still need something like a 1/4" drive long extension and socket. Threaded lug will probably snap anyway. Always suprises me that there is no gasket behind these handles, should there be?
Brian
phreak97
  • Niki!
« Reply #2 on: July 24, 2007, 01:36:54 AM »
thats pretty much how i did it, and even doing that its difficult to get the socket in there, because the door lock is still in the way. probably would get easier if i did it a couple of times.
phreak97
jose
Re: WOW door handles are hard to remove....
« Reply #3 on: December 17, 2009, 12:50:55 AM »
in my bis i found that i had to unscrew the door catch and drop it down to access the second bolt, and for some reason the hole in the door still didn't line up enough to refit the handle. i cross-threaded the nut! >:(
i didn't have any probs with the window runner tho, maybe different on different models. and i still had to use a wobbley extension with the 8mm socket to get it to line up!
126BIS 1990
