Author Topic: Fire?  (Read 3256 times)
Fire?
« on: June 28, 2007, 09:21:14 AM »
Drove to work this morning in my BIS and noticed lots of smoke coming from the back.  Feared the worst and thought it was the head gasket!  However on closed inspection it turned out to be the rocker gasket.  It has split and is dripping oil onto the exhaust.  I live about 10 miles away do you think that it will catch fire on the way home?
Fire?
« Reply #1 on: June 28, 2007, 10:15:22 AM »
I would not chance it!
I saw a tv program and one of the main causes of engines catching fire was oil going onto the exhaust manifold in this case it was brake fluid. The strange thing was that they tested a petrol leak onto an exhaust manifold and it was ok? :shock:
But don't try it!
Fire?
« Reply #2 on: June 28, 2007, 10:17:32 AM »
i wouldnt,oil goes better than petrol!!..why not drain all the oil out then drive it back?  :lol:
Fire?
« Reply #3 on: June 28, 2007, 03:08:46 PM »
Have you got break down cover?
Get a taxi home come back to work next day with new rocker cover gasket and 10mm
regards
Fire?
« Reply #4 on: June 28, 2007, 03:38:14 PM »
dont panic just take off the rocker cover and clean up the surfaces and use some liquid gasket as a temporary fix , i done it on mine and have been driving around for ages .! be sure if you do use this that you leave it about an hour before driving on it.
Fire?
« Reply #5 on: June 28, 2007, 06:27:30 PM »
Thanks for all your help!  I robbed a spanner from work and did up the rocker cover nuts, would you believe they had come loose?  It is still leaking a little but it got me home.  Gonna strip it tomorrow and fit a new gasket!
Fire?
« Reply #6 on: June 28, 2007, 07:28:47 PM »
to be honest i have been driving around with a multitude of gaskets in my car since mine went and i still have not fitted a new rocker cover gasket. i do however always carry a well stocked toolbox, spare battery, jump leads,trolley jack,fuses, assorted nuts and bolts,points and condenser, spare bulbs,and alternator belt. it sounds overkill but all these things have gone in the past and i just think next time i will be ready. i might start towing another 126 behind just in case! :lol:
Tommo32
Fire?
« Reply #7 on: June 28, 2007, 08:30:23 PM »
petrol evapourates too fast to cause fire. oil can build up on your exhaust untill it gets so hot it lights.
Fire?
« Reply #8 on: July 08, 2007, 11:04:01 AM »
Changed the rocker gasket now.  It was made of paper my new one is made of rubber and stopper the leak.  Washed engine and exhust down with degreasent and everything seems fine now!
thanks for all your input!
Fire?
« Reply #9 on: July 08, 2007, 01:05:51 PM »
good work fella
