Author Topic: Brakes don't work anymore!!  (Read 3377 times)
« on: June 24, 2007, 07:54:36 PM »
I could do with a bit of advice on my brakes.
They passed the MOT last year in July and have been getting gradually worse as time has got on.
Theres alot of travel in the pedal and the bite is very on/off. the rear brakes are especially poor.
There has been no fluid loss from the reservoir and no sign of any leaks underneath.
I tried bleeding them today but o no avail. I was getting nothing through to the rear wheels - no air, very little fluids.
I adapted my easy bleed kit and tried that. I was getting a very poor trickle of fluids through which increased slightly when the pedal was pressed. The end result is that you can turn the rear wheels by hand when the brakes are on!
It is a 500, but the set up is as follows:
126 wheel cylinders - new last June
126 shoes - New last June
126 Master cylinder - New last June (installed upside down - does this make a difference??)
From what I can gather, the fluid isn't being pulled from the reservoir to the master cylinder and I cant fathem out why. If it is caused by the master being upside down then the use of  pressure from the easi bleed should have sorted this out.
Any ideas?
Michael
jpimpao
« Reply #1 on: June 24, 2007, 08:34:38 PM »
It is worth to have a look at the wheel drums and shoes as they get dirty , with time they get shinny and don`t work propely, clean drums with degreaser ,sells in spray, this stuff usually evaporates and after it`s dry scrub drums and shoes with sand paper ( thin ) to take out all the shinny bits, if there is any, and see if there is any improvement .
Hope it works.
Jorge
« Reply #2 on: June 24, 2007, 08:47:06 PM »
Thanks for that.
Unfortunately my problem is a little more fundamental than that as the shoes dont move out to meet the drum in order for glazing to be an issue!!
its definately a master cylinder related issue.
« Reply #3 on: June 24, 2007, 08:56:16 PM »
i would think its because the master cylinder is upside down, when it is the wright way up any air thats trapped in the chamber will float up the pipe to the reservoir. also any air trapped in the system would float up to its highest point which would be the chamber of the m/cyl but would be trapped because the outlets at the bottom, when you depress the footbrake it would pump fluid first because the outlet is at the bottom, if there is air in the chamber it will be at the top and can't escape, it would be difficult to dislodge, just a thought.
« Reply #4 on: June 24, 2007, 09:58:17 PM »
Could be the master cylinder piston not coming the whole way up.
As I understand it, at the top is when fluid goes into the master cylinder.
This could explain the lack of fluid being pumped through.
You got nothing to loose as the brakes dont work, I'd pull the master out, strip and clean, maybe put new seals in as it's a job not worth doing twice....and especially not in this weather we having this weekend!
« Reply #5 on: June 24, 2007, 10:38:27 PM »
As it happens I have a new one still in its box. I think it's going on tomorrow!!
I dont think its failed, but you're right - i have nothing to lose.
I'll stick it on the right way round this time, means re-bending the pipes but i need to rule it out.
As I'm using the 500 pedal box i suspect my pedal rod is incorrect in length and position as the 126 pedal rod follows a different arc. Thats something for me to do during lunch. The joys of working in a workshop!!
I made alot of problems for myself fitting this stuff many years ago without contemplating the possible side effects
« Reply #6 on: June 24, 2007, 10:50:50 PM »
Some days I wish I still worked in a workshop!
I used to work for a company making stuff out of stainless steel.
Imagine what my 126 would have in it now...stainless everything possible!
We had a large selection of stainless metric nuts and bolts too!
« Reply #7 on: June 24, 2007, 10:55:25 PM »
Stainless would make my life alot easier!!
We have laithe and CNC and a grit blaster despite the fact its never used!
A very good spray booth, which may be large enough to fit fiat panels!!
We mainly do vacuum casting which should be very good for replicating plastic parts. Not ben working there too long so I dont want to take the mic just yet!!
« Reply #8 on: June 24, 2007, 10:59:07 PM »
Hey the grit blaster would be very useful!
You should ask if they will do jobs for club members.
We'd pay but maybe we could get a discount! :P
« Reply #9 on: June 24, 2007, 10:59:08 PM »
the upside down bit would have showed itself when you installed it..........it wouldnt have bled up....i had brake probs the other day,rear wheel sticking on.........i did all the usual stuf and ended up bleeding the rear circuit,now,the prob was no fluid was coming out at all with the usual steady pumping,it was only with some rather savage ''im fed up with this'' pumping that anything started to happen,i think an air lock may have occured.....just a thought........
« Reply #10 on: June 24, 2007, 11:14:04 PM »
you could try this trick from paul harbinson a forum member
"Ok Richard lets go back to basics and try this,sometimes have to do it on the jags.Fill the reservoir tp the top,then,open all the bleed nipples (put something under each wheel to catch fluid).What you do then is go into the house for half an hour (occasionally returning to top up the fluid) and have a cup of tea and a chocolate hob nob.Let gravity do the work."
« Reply #11 on: June 25, 2007, 02:37:44 PM »
Thanks for those guys.
I remember being a bit heavy handed the last time i blead it.
I'm sure the eazi bleed would have forced things along though!!
I remember it being a real pain to bleed last time as it was installed upside down so I think i'll turn it round while im playing with the brakes and then go for the savage bleed.
That gravity plans sounds like it would suit my usual work ethics alot better though!!
