Author Topic: Fitting a fag lighter  (Read 1747 times)
Idle Steve
    • http://www.mb5.co.uk
« on: June 20, 2007, 11:03:15 PM »
Shocked at not being able to plug the old sat nav in anywhere, I was on a mission to fit a fag lighter socket.
No problem as the blanking plate popped out (Bis) and lo and behold there was a wire and plug just waiting to be connected. This proved to be a constant live, a neutral and a wire which came live when the lights were on so it would even light up in the dark!
Down to the scrap yard and found one out of a Rover 25 which had never been used. :D
Back home and guess what? The plug fitted straight on to the lighter socket and the lights on wire fitted straight to the illuminating bulb.
Every thing hunky dory then? NO! :smt012
The wires in the fitted connector are the opposite way round in the Rover to the Fiat so the polarity in the socket was wrong. This was noticed when the thing failed to illuminate (Bloody good job the sat nav was not plugged in). :sad:
Just worth mentioning in case any one is thinking of doing the same. The terminals can be pinnged out of the connector and swapped over easy enough.
Steve.
The wife calls Him "Cecil"
« Reply #1 on: June 21, 2007, 05:09:58 PM »
heaven knows why you need a sat nav in a bis , a bit of paper with a home drawn map is more de riguer ....just dont stick it on the windscreen you wont be able to see past it!
Idle Steve
« Reply #2 on: June 21, 2007, 06:00:38 PM »
The wife uses it so she dosn't get lost going to Tesco 2 miles down the road!!!!!! :???:
« Reply #3 on: June 22, 2007, 07:16:34 AM »
my wife once went for a job interview in westerham then should have drove back to sittingbourne......she rang me from windsor .......women and sat nav = very good idea. :D
« Reply #4 on: June 22, 2007, 11:36:38 AM »
steve, another alternative is to get a jump starter pack, i have one and it comes with a fag lighter socket, whenever ive done long trips ive plugged my sat nav into it.
just an alternative if you really need to use your sat nav, and always good to carry a jump start pack, theyre only £40.
regards
