Author Topic: Gearbox and diff oil  (Read 4494 times)
rcarter
« on: June 20, 2007, 10:00:08 PM »
Is the diff in the gearbox. this is a 126BIS H reg 4 speed box. Also where is the level filer plug.
Ray
« Reply #1 on: June 20, 2007, 10:15:33 PM »
the filler plug is on the starter motor side of the box,and located just under the starter motor,diff is in the box,make sure you can undo the filler BEFORE you drain the box,its not unknown for it to be seized solid..and is very hard to remove once rounded off.....good luck.
check out the ''if it aint broke dont fix it'' thread......a small job can turn to nightmare...the filler plug is steel in the alloy box and does tend to sieze in
Idle Steve
    • http://www.mb5.co.uk
« Reply #2 on: June 20, 2007, 10:17:40 PM »
Hi Ray, the dif is combined in the gearbox transaxle.
The level plug is up by the side of the drivers side driveshaft, it has a square head and is a bit difficult to get at. :cry:
Steve.
The wife calls Him "Cecil"
Idle Steve
« Reply #3 on: June 20, 2007, 10:20:21 PM »
Got there before me Dave! :cry:
Was trying to type & eat a donner kebab at the same time!
« Reply #4 on: June 20, 2007, 10:36:23 PM »
banjomandolin
G/box/diff oil level plug.
« Reply #5 on: June 20, 2007, 11:50:54 PM »
I have fould that you can hammer an appropriate size imperial socket onto the square filler plug turned by a long extension (add 2 together).
John Clark
« Reply #6 on: June 21, 2007, 05:17:42 PM »
there is also the option of going down and buying the proper tool for the job of course which does make for an easier time eventually.
banjomandolin
Gearbox Plug.
« Reply #7 on: June 29, 2007, 08:30:39 PM »
What is the special tool for a male square headed plug that has the four edges thoroughly burred over through constant attempts at turning it with well worn open ended spanners ?.
John Clark
« Reply #8 on: June 29, 2007, 08:42:18 PM »
well,drill a pilot hole carefully then use a good quality 'easi-out' judiciously hammered in,then hopefully you can get it out...........good luck  :wink:
« Reply #9 on: June 29, 2007, 08:46:31 PM »
have you tried a 1/2" socket extention bar the wrong way around?
Re: Gearbox Plug.
« Reply #10 on: June 29, 2007, 10:16:10 PM »
Quote from: "banjomandolin"
        if you go to any good auto shop you will find a whole selection of " special tools" that are intended to be used for the jobs they are designed for thus evading the smashed up state that you find on most gearboxes.
if the edges are burred over get in there with a dremel if you have one they are superb for these sort of problems.
banjomandolin
Gearbox plug.
« Reply #11 on: July 02, 2007, 11:02:16 PM »
What is a dremel ?.
John Clark
Idle Steve
« Reply #12 on: July 03, 2007, 12:38:03 AM »
