Author Topic: bis in need of help  (Read 4456 times)
elbisto
bis in need of help
« on: June 13, 2007, 11:19:30 PM »
hi folks
dont know if anyone can help with any of these problems with my 126 bis, any advice would be good
first she is not reaching full power when going up hill, been noticing it for a few weeks, i thought it could be the clutch going
ive got a new clutch but im not sure if its from a bis or a 126 are they much the same? the part no is 3000289001  HK8861 any ideas?
also how much of a job is fitting a new clutch? do i have to remove engine/gearbox etc?
secondly, there is a really strong petrol smell in the car all the time, it reeks , what would be the first places to check for this?
thirdly there is a hole in the exhaust, is it just a case of  whipping of the old one and fitting a new? is there any other parts that are usually worn/need replaced
if you couldnt guess i dont know too much about the car innards, but id like to try and fix these probs myself. i have a spare bis that id like to take the engine out and recondition for the runner, so i dont know if its worth doing all the work at once, take her off the road as mot is up soon.
i imagine the engine will be a big job, and a hard one for me. any pointers or where to start looking for tips would be great
cheers
Wozza
bis in need of help
« Reply #1 on: June 14, 2007, 12:00:29 AM »
I wouldnt worry about the clutch mate, a little oil seepage is normal from the gearbox mating too, its a big job to cure it though, and mine still works after a year of leaking here or there. The clutches on a bis are near enough bullet proof  :) . If you can smell petrol before you start your Bis from cold, take a look at the engine. if you can see petrol in between the engine block ribs its a petrol pipe fault. and fit an in-line filter when you fix it mate. I think it's more likely to be the hole in the exhaust though , the Bis relies on the back pressure from the exhaust system to get anywhere, and if that leaks all the time then your engine will be down on power, I would suggest an exhaust swap from your spare car if you cant find any leak in the fuel supply mate. if that doesnt cure it then let me know...
elbisto
bis in need of help
« Reply #2 on: June 14, 2007, 02:11:30 PM »
ok ill give that a wshot, i have a whole spare exhaust here so ill make that my first port of call. There is some liquid on the engine ribs but im not sure if its oil, ill investigate further, ubt try the exhaust swap first
cheers for now
Idle Steve
    • http://www.mb5.co.uk
bis in need of help
« Reply #3 on: June 14, 2007, 09:53:04 PM »
Check the fuel pipe from the pump to the carb, the old cloth covered ones seem to leak after a while. Feel if it is damp and smells of petrol.
Also check the two coming from the tank.
Stick your head underneath and see if the fuel tank is wet after a run or when you can smell the petrol, it could have a hole near the top and leaks when the petrol is slopping about.
Steve.
The wife calls Him "Cecil"
banjomandolin
Back pressure.
« Reply #4 on: June 14, 2007, 11:24:21 PM »
Hey Wozza, Where do you get the idea from that the Bis needs exhaust back pressure in order to maintain power ?. Back pressure is what the engine tuners are trying to eliminate hence big bore straight through exhausts.
John Clark
bis in need of help
« Reply #5 on: June 15, 2007, 01:56:02 PM »
no warren is right, i was always under the impression that straight through exhausts were least restricting, but engines apparently need a bit of back pressure, i dont know why, i wish i knew, alot of tuners have told me it is needed.
regards
bis in need of help
« Reply #6 on: June 15, 2007, 03:07:36 PM »
you can loose some back pressure however to throw fuel to the fire how come when i removed my exhaust and ran the car with just two down pipes from the manifold (about 200mm length and standard bore) my car although sounding like a mental harley d went better than ever with no running problems what so ever? the acceleration and top speed went up incredibly . even with a sport "auspuff" the car ran better this had less baffle so reduced back pressure as well. unfortunately my fat arse pushed the rusty floor pan out floorwards as lakin knows!! and my right foot tried to kill the motor on the way back from uxbridge i drove off the clock for most of the trip from there to mid kent and it didnt worry the bloody thing! who said the bis is a problem waiting to happen?  :D
banjomandolin
Backpressure.
« Reply #7 on: June 16, 2007, 10:52:53 PM »
I am surprised that no one has mentioned that the last 200mm of exhaust tailpipe on the air cooled is flattened so is this to create backpressure ?. Four years ago I was running a 600cc aircooled and just for an experiment removed the flattening by squashing it in a vice to make it round. This made no difference whatsoever to the engine performance.
John Clark
bis in need of help
« Reply #8 on: June 16, 2007, 11:21:57 PM »
my bog standard a/c is running with the flat bit cut off,dont think any performance diff apart from exhaust not looking so cartoony.....it sounds like a bis now tho...
Wozza
bis in need of help
« Reply #9 on: June 17, 2007, 10:58:20 PM »
Ill try to explain it a bit better, It is a complex subject because you would need to examine each different design of engine in detail, no two engines from different manufacturers will work the same even if they are both using exactly the same exhaust system. Backpressure in the exhaust system up to a certain level helps to produce torque in the engine. this is normally governed by the diameter of the pipes and their intersections. The problem is that gaining too much torque seriuosly hampers an engine when it revs fast, which is where it creates the most actual horsepower!. so to create horsepower with a large bore exhaust that works high up in the rev range, you end up losing backpressure and hence torque, from lower down the rev range. to tune an exhaust to acheive both of these is only effective if you have also considered a great many other factors involving the main parts of the engine first. hope that helps :wink:
elbisto
bis in need of help
« Reply #10 on: July 04, 2007, 09:37:42 PM »
ok
ive managed to remove the exhaust from the bis but the other one i have has different fittings, possibly from an earlier model
i cant get the one off of the spare car as one bolt is seized and no matter which angle i try from i cant get it unseized ,does anyone have any suggestions? ive tried with car on axle stands and also with a spanner/crowbar/hammer combo but it doesnt wanna budge
i cant afford a new exhaust for now, so would anyone recommend exhaust fixing putty?the hole is located under the rearmost bracket making it a bit awkward to get to, but it is a very small hole, so do you think it would stay fixed for at least a month or two with the putty?
any help on this would be great to get her back on the road as it makes me very sad to see her sitting on the drive every day :cry:
Wozza
bis in need of help
« Reply #11 on: July 05, 2007, 10:30:06 PM »
I dont think applying putty is going to last any more than a fortnight, but you could try it. The best solution would be to weld a small plate over the hole, an ideal plate would be L shaped but shallow, so that it could be welded against both the silencer and the hanging bracket for strength. Try giving the seized bolt an overnight soak in WD40, and then a few good knocks with a metal hammer. Or warm it up with a blow torch and then try to free it. As a last resort you might be able to undo the four bolts on the side of the cylinder head holding the upper mounting plates, and slide the exhaust off that way. Sit the car on some axle stands/ramps while you do that though: or you may struggle to move the exhaust from under the car afterwards with those upper plates on it. Good luck.
