Author Topic: If it aint broke don't fix it!!!!  (Read 1889 times)
Idle Steve
    • http://www.mb5.co.uk
« on: June 10, 2007, 05:01:23 PM »
The old Bis was sounding like a cemant mixer so time to set the tappets. Ah! whilst I'm at it Ill torque the head bolts, no problem just remove the carb (bloody faffy 10mm nuts). Oh dear can't get to the head bolts without removing the inlet manifold. :???:  No problem only 3 nuts, Ah! the coolant runs through it time to drain the brand new anti-freeze (Bugger, get out the bucket it's going back in) :)
Carefully remove the manifold so the gasket can be re-used with a bit of instant gasket. Oh dear it's split in two! :cry:
Remove the rockershaft nuts only to find they have been overtightend and the threads damaged. :evil:
Out with a die and recover the threads source two new nuts.
Out with the torque wrench only to find the head bolts well tight and did not need any attention.
Out with the gasket paper and make new gaskets, replace rocker shaft a couple of washers to move the nut further up the shaft onto good thread.
Set the tappets and re-assemble everything.
Remember if it aint broke DON'T fix it!!!!!!!!!!!!!!!!!!!!!!!!!!! :smt023
The wife calls Him "Cecil"
« Reply #1 on: June 10, 2007, 05:08:55 PM »
i know i know......been there as well,re torqued head bolts on perfect running air cooled and pulled the threads on one stud............. ended up pulling head,re making a stud and putting all back with new gaskets etc.......+ unscheduled oil change to boot :roll:
« Reply #2 on: June 10, 2007, 09:07:08 PM »
BUT now you know its all fine and good ..thats the plus side!
