Author Topic: peugeot partner  (Read 1835 times)
nrg19uk
peugeot partner
« on: June 09, 2007, 09:31:24 PM »
i know its a 126 forum but i am having problems with my partner van, every time i turn left i get a metal squeal from the right hand side front wheel i have taken it to a garage thinking its the wheel bearing only to be informed it was the drive shaft so i get one of those fitted and i still have the same squeal any budding mechanics out there that can shed a little light.
thanks neil
Neil gargaro
toz
peugeot partner
« Reply #1 on: June 09, 2007, 09:46:01 PM »
hi,it could be that the lower arm is bent or your tracking is way out,this is a small guess as ive never even seen it.
just an idea but would get it looked at,but like you say could be a bearing but it should do it both ways if that was the case.
Wozza
peugeot partner
« Reply #2 on: June 09, 2007, 10:04:07 PM »
If you get any vibration through the steering at motorway sort of speeds, then it might be a warped brake disk mate, or the wheel bearing as you thought  :???: . The power steering could dampen any such vibrations at low speeds. check your brake pads for excessive wear on the outer one.
nrg19uk
erm
« Reply #3 on: June 09, 2007, 10:17:10 PM »
when im on the motorway i dont feel a thing i can let go of the steering wheel and it will sit there in a straight line, but when i slow to about 20mph it squeals
Neil gargaro
Wozza
peugeot partner
« Reply #4 on: June 17, 2007, 10:23:19 PM »
Sorry neil, ive been a bit busy this last week, if youre still having problems, ill speak to my mate who is a garage mechanic on tuesday night. He might have a better idea of the cause, because ive run out of ideas for you at the moment mate :???: .
