Author Topic: Alternator parts  (Read 2783 times)
Alternator parts
« on: June 05, 2007, 04:56:59 PM »
My alternator fell off yesterday on the way home from work, all I lost though is the mounting bolt that holds it on and the belt, where could I get ethier of hese items?
Alternator parts
« Reply #1 on: June 05, 2007, 05:08:30 PM »
i think i have the bolt here in my hand give me your address again and you can have a look . mick
Alternator parts
« Reply #2 on: June 07, 2007, 07:47:18 PM »
What size belt do I need?
Alternator parts
« Reply #3 on: June 07, 2007, 07:49:59 PM »
the belt i the standard alternator drive belt the aircooled and bis are the same have alook on ebay or try your local motor factors i have one but i need it as a spare and postage would cost as much as a belt would from a shop.
Alternator parts
« Reply #4 on: June 07, 2007, 07:51:34 PM »
Ta
banjomandolin
Belts and bolts
« Reply #5 on: June 08, 2007, 08:46:29 PM »
Hi Andrew, I have both the long and the short bolts for the alternator, also I have two belts taped together with a note that says
" 126Bis or 2CV ?". so it could be that your 2CV belt will fit. Fly up the M1 for a look if you wish.
John Clark
Alternator parts
« Reply #6 on: June 09, 2007, 09:03:43 AM »
Hi Banjo
you are back from your hols then!  Nice time?
banjomandolin
3 Months in Oz.
« Reply #7 on: June 09, 2007, 05:26:38 PM »
Yes thank you but didn't see a single 126 nor 2CV !
John Clark
Alternator parts
« Reply #8 on: June 10, 2007, 11:11:55 AM »
All repaired thanks for your help, I hope it dosen't fall off again, I'll have to keep a check!
