Author Topic: Bis Gearbox mounts req  (Read 3281 times)
Idle Steve
    • http://www.mb5.co.uk
« on: May 29, 2007, 10:10:53 PM »
Hi all,
As it's been 10 years since my last Bis, who is the best for spares these days? I'm after a couple of gearbox mounts as mine are absolutlely cream crackered.  :smt089
Thanks,  Steve.
The wife calls Him "Cecil"
« Reply #1 on: May 29, 2007, 11:43:15 PM »
hi mate, the BIS gearbox mounts are quite expensive,
www.ricambio.co.uk are your best bet give them a call, they are reliable youre looking at £30 +
regards
« Reply #2 on: May 30, 2007, 03:04:10 PM »
have a look at this site the guy is a buggy builder but used poly bushes to replace the mounts , its well worth a go and they will last longer.
http://www.k9rdj.co.uk/mybuggy/chassis.htm
mick
Idle Steve
« Reply #3 on: May 30, 2007, 06:00:31 PM »
The Poly bushes look quite good, however the rubber ones are designed to move a fair bit damping out the vibration from the body. The only thing that worries me a bit is that there will be too much vibration carried through to the body causing my false teeth to fall out! :smt093
What do other people think? :|
« Reply #4 on: May 30, 2007, 06:07:55 PM »
part of the reason the bushes go is the fact that the clutch is usually contaminated with oil,causing savage take up on the sticky clutch,every 126 i have worked on has had the gearbox input shaft seal weeping,i reckon the standard ones are ok with a good clutch and driving technique
Idle Steve
« Reply #5 on: May 30, 2007, 06:43:32 PM »
It's had a new clutch before I got it (and a reciept for a new crankshaft oil seal no less!)  The clutch is quite nice, the rubbers have perished due to old age (know how they feel!) :sad:
Has anyone used this website ? https://ssl.kundenserver.de/shop.fiat500126.de/indexa.htm
The parts look cheap and the postage is not bad if you buy a few things.
« Reply #6 on: May 30, 2007, 09:38:59 PM »
the front crank seal goes as well...... :wink: gerstl are good for standard parts,but some here have had long waits tho....
« Reply #7 on: May 31, 2007, 07:25:16 AM »
achtung!! jonny!! givs me vor monzey unt i back orderz ze partz!!
« Reply #8 on: May 31, 2007, 08:12:13 AM »
if you do as uncle Dave has said in another string, email them first to make sure they have the parts in stock, i had to cancel part of my order after waiting 10 weeks,
