Author Topic: bloody starter cable sorted.  (Read 1740 times)
« on: May 21, 2007, 04:57:04 PM »
have you got the old pull starter? keep breaking cables? get down to a diy store and buy some 3mm steel wire rope and some of the small wire rope clamps and make your own heavy duty starter cable. for the outer use an old larger diameter outer or some fairly rigid heatproof tube . i have a brass anchor point at the starter end which i drilled out to take the wider outer  and 3mm cable ( most are plastic) . first insert the wire rope throuh your new outer . attach the wire through the interior starter handle and make a loop fasten with a clamp, make sure all the cabling and anchor points are correct then loop your cable through the metal gizmo which is normally at the end of a starter cable , you will have to test to see if its tight enough to activate the starter then tighten up the loop again with a wire rope clamp. i bought 3 meters of cable but have cut loads off on the finished cable i will measure and post it later. it takes a little time to get it to the correct length but i am sure in the longrun will be cheaper and stronger than the original , and i am fed up of starting the car with a stick!!
« Reply #1 on: May 21, 2007, 05:25:26 PM »
loks like im going to have to resort to this.
you just dont know your own strength when you pull that cable lever!  :smt098
