Author Topic: Couple of maintenance issues  (Read 2094 times)
Matt S
« on: May 20, 2007, 04:54:14 PM »
Hi folks,
I've found that after a shortperiod of inactivity the little BIS has a marked lack of breaking power, I believe one of the wheel cyclinders on the front has seized off.
Are they a fairly normal drum brake assembly?  If so im happy to just whip it all apart and sort it, just thought id check first though.
Also
Kingpins, do they need periodical re-greasing?  Most other cars i've had with kingpins have grease nipple but i cant seeanything obvious on the fiat.  am i missing something or dont they have one?
« Reply #1 on: May 20, 2007, 05:24:27 PM »
Hi the brakes are as simple as you can get, pretty old school stuff, there almost the same set up as the rear, with the exception of the hub shaft which is'nt there, once you whip off the drum, just back the shoes off and you can work the wheel cylinders back and forth with a flat head screw driver
as for the kin pins, yes they do have a grease nipple, if you turn the wheel on full lock ( i forget which way ) its found lurking at the back, these  DO need geasing regulary best to do every other month because if they wear ( and they do trust me! ) there a ball-ache to change :wink:
« Reply #2 on: May 20, 2007, 08:43:49 PM »
the auto adjusters are prone to sticking,i clean my back hubs and front calipers out with STP brake cleaner...it helps...also bleed the system,its prob well over due....
yes the king pins do have nipples,but do jack up before greasing,and do some lock to lock while greasing.....
while your at it do the slider/inner hub joints as well....... :cool:
Matt S
« Reply #3 on: May 22, 2007, 09:16:03 AM »
thanks folks, another job for the weekend :)
